4 threads found!
Haruchai | 105 | 7126 | |
Haruchai | 20 | 701 | ||
Haruchai | 4 | 122 | ||
Haruchai | 6 | 155 |
184 comments found!
As I said I understand that things move on and this will leave old things behind. I'll do what I did a few versions ago, upgrade and run both side by side sharing a Runtime, unless that's not feasible for some reason, until the Python updates start to come through making 11 redundant. Thanks for all info, appreciated.
Poser Pro 11, DAZ Studio 4.9
Thread: Poser 12 Python compatibility question | Forum: Poser 12
McGrandpa posted at 3:37PM Tue, 03 November 2020 - #4403047
@ Haruchai - check the Scripts Menu dropdown for new versions of ShaderWorks scripts. I saw that folder being installed earlier.
Sorry, not sure where you mean to check. If you mean in 12 I haven't upgraded yet. If you're saying there are new versions already in 12 then that is great. Could you clarify, I'd appreciate it.
Thanks for the replies. Yeah, Library Manager was the main one I was thinking about but there are lots of scripts I use a LOT. There is little to no chance of the ShaderWorks ones being updated as I believe the vendor left the Poser space when RDNA changed hands. More than happy if someone can correct that assumption but right now I have a new features/old functionality decision to make. BTW, really happy that Poser is getting the attention it deserves and I understand things move on, and rightly so.
Thread: Windows, Poser re-installed, some V4 DAZ morphs don't work. | Forum: Poser - OFFICIAL
quietrob posted at 6:15PM Tue, 09 August 2016 - #4279237
Here is my !DAZ files including locations in case my problem didn't make sense.
What is in the Runtime folder you have highlighted? This could be a classic case of runtime nesting i.e. Runtime within a Runtime. If it contains geometries, libraries and textures folders these need to be moved to the main Runtime
No worries, it's good to be able to give back after learning so much from others.
At the risk of labouring the point here are a couple of screenshots to illustrate what I mean (I'm very visual and pictures always help me).
As you can see none of this content is on my C: drive where the Poser program is installed, everything is moved to an external drive. Just make sure that any !DAZ folders in the Poser runtime libraries are moved to the Poser Content library folder. For example I have a Laura folder in the Poser Content/Runtime/Libraries/!DAZ folder but all the character files, props, morph iNJ files etc are in the Poser Runtimes/DAZ 3 Kids folder. As long as all these Runtimes are mapped to the Poser program everything functions perfectly.
Don't terminate with extreme prejudice!
The thing is that when you install things to various runtimes more than one !Daz folder can result. This leads Poser to get confused when looking for the !DAZ folder being called, it will only find the subset of morphs in the one it finds and this is what causes the problems.
What I do is manually MOVE any content in other !DAZ folders to the main one in my Poser Content folder. This means that all morphs, INJ deltas etc are only ever in one folder but they are all there. If you delete the second folder you find you will be deleting the morphs it contains which kind of defeats the point of the exercise.
Hope this helps
Glad you got it sorted, just passing along the wisdom given to me a long while ago when I had this issue but it stayed with me for some reason.
If you have multiple Runtimes have you checked that you only have one version of the !DAZ folder?
I had a lot of issues at one time which was sorted by combining two !Daz folders in to one in the Poser Content library folder.
BTW, I think this is where the 'You must have V4 in your main runtime' myth came from. I quite happily run M4 and V4 from separate runtimes but they all refer back to the one !DAZ folder for the morphs and the exp batch files work no problem to update morphs.
Thread: Changes to Renderosity - is it just me | Forum: Poser - OFFICIAL
**** In the market place items I have already purchased are not showing as so and they also allow me to put the item into my card. This is not a one off as I have checked a number of items.
I am hoping this is a temporary condition (apart from the spell checker) and not something that has happened on my PC alone. ****
Same thing happening for me, pity, this was the best implementation of how to check what you have already bought of any store I have used.
Seconding the hope this is only temporary.
Thread: more Japanese freebies | Forum: Freestuff
Quote - > Quote - can anyone help me downloading this helmet??
http://artistside.com/?m=pc&a=page_fh_content&target_c_diary_id=41622
i did the whole registry proces ,... but the site refuses to letme in
I have exactly the same issue.
Not sure this is actually of any help but it does work. I signed up to Artistside ages ago. Just copied your link into my browser, signed in and downloaded the file.
Is there a confirmation email process, can't remember, but I can confirm that the file is still there and downloadable.
Thanks musicat.
Whilst on the Redviper Pixiv page I notices that the Sleeveless Tennis Wear and Traditional Sailor Uniform for A4 both got an April 2014 update.
http://www.sharecg.com/v/65704/gallery/11/Poser/Sleeveless-tennis-wear-for-A4-minor-fix
http://www.sharecg.com/v/63622/view/11/Poser/The-Traditional-sailor-uniform-for-A4
For anyone else who may have missed them
Quote - Thanks!
But, happily, the Gift 1 link isn't gone, it's just incorrectly written on the front page :) It's linked correctly at the top of the page called Gift 2. Several gifts there, in fact :)
Actually, Gift1 was originally a Genesis Outfit called Rough Sweat. Featured here
http://thfreestyle.blog.fc2.com/blog-entry-351.html
but it seems to have gone from the site. I downloaded it in January, maybe a more in depth hunt of the site will bring it to light.
Quote - > Quote - tweety has added a motorcycle for momimomi
Um...how does one go about downloading this?
I haven't been able to find a download button...
You need to be signed in to Artistside before the download button will show.
If you need to sign up try viewing the page through a translation site.
Thread: Stockings solved...at last | Forum: Poser - OFFICIAL
Never tried dynamic ones, will investigate :)
Thread: the Dawn of a new day... | Forum: Freestuff
Oh no, I'm going to miss the launch. Have to leave for a one week trip early in the morning of the 9th (UK time) and will only have sporadic internet access at best.
Hope no one does any 'one day only' launch sales! Been waiting for her for so long and I'm going to miss the party, bummer.
