3 threads found!
HolyDiver | 4 | 84 | ||
HolyDiver | 4 | 103 | ||
HolyDiver | 3 | 185 |
24 comments found!
Good luck to you, I'm considering the same avenue. Finally got an interview for some Temp work in a technical position for Fri.
Funny/Sad part, the position is with a company that took the inexperienced guy (read lower pay) than the one (me) with 30 years experience about a month ago. I really can't wait to meet this guy. I hope I can hold onto my temper til the gig is up......hehehe
At this rate I should be able to put something in my wish list in 2 or 3 years.
Thread: P7 Magnets | Forum: Poser - OFFICIAL
Well I got 90% of what I aimed for, finally just settled on saving the 3 mags as 1 prop. Yes JB, "kielomorph" was at 1 and I tried to match the V3 head with mags and spawn morph target. Clicking on the mags as a prop gets me there so the end result is what I was shooting for. Will have to remember to apply them each time to each like character but worse things have happened. Thanx again everyone.....HD
I'm sure the 2 had a good bit of intersecting with each other. I've saved the Mags as props grouped together. Perhaps I should load 1 at a time and spawn from there. It'll be a bit before I can try it but thank you very much for giving me a direction to try. (Other than forward movement of my PC thru the nearest window) Thanx again, good idea, perhaps before I never had more than 1 magnet at a time...........HD
Thread: OT: My backup device causing boot-up problems | Forum: Poser - OFFICIAL
Isn't USB (in part) defined by the connection? If its permanent how can it be USB. Rhymes not intentional....
Thread: Installed new hard drive and computer running slow. Why? | Forum: Poser - OFFICIAL
Now I'm worried haha........
I inquired in part because I have a "My Book" 500 gig. I've seen some interesting concerns
about them and some may be from here, maybe I should back it up to C: just in case. I do wonder
what was the interface you used when you installed it and what is your OS. Been wanting a
bigger one but do I want another "My Book"???Hmmmm
Hey Lululee,
I'm curious, did the "new" drive hook up as a parallel drive (40 pins, big thick cable) ? or a serial drive with the newer thin cable??? Are they on the same cable (master/slave setup) Some more
info such as original drive Type/Size/Speed or Rpm and XP or Vista OS would help. I think my "My
Book" is an older 7200 rpm Parallel drive. They make kits I think to convert old drives into USB drives. More info would be helpful. Have you double checked any jumper settings on the "new"
drive??? I'll try to check back later but more info would be helpful, even the brand name unless
you built this yourself. If so you may wanna check the manual on your mother board. Quite a good idea on your part doing this, kudos for that. (Were new power supplies that expensive, any
options on a generic power supply, some thing with different voltages and polarity at the drive
side of the supply??? Later......Holy Diver
Oh, you could always back up and punt, meaning disconnect the "new" one and make sure
everything is OK as originally thought. Just to be sure. You never know with Poser.....
Thread: Will people be using The Girl 4? | Forum: Poser - OFFICIAL
I lined up the base figures (V4, A4, G4) and just cant get over her size, she's the tallest of the three and compare that head size, the arms n hands, now the feet. I use some of the body morph on A4 and V4 but darn Daz. To me she's huge. I can deal with the arms and hands as a morph but those feet, oh boy. In conjunction with V4 and A4 she works well with the Elite and Pretty Base 4 morphs and so far with another tool I've got no problem clothing them. But as a character, no I think they missed the boat. I can't afford another mouth to feed n clothe. I'll pass and have to stick to what I've got for V4 items. Buying more napkin wear and hair isn't gonna happen. And what happened to cute 'n cuddley??? IMHO.........HD
Thread: Cross Dresser 3 Question | Forum: Poser - OFFICIAL
Just a thought, I do have XD3 but not the morph packs. For morphs I suggest Morphing Clothes by
Ralf Sesseler here. Load the CR2 the way you want it, save, load into "MC" and transfer til you're contented. It handles heads, feet, and hands IMO much better and even on older systems it zips thru so quick its amazing. I haven't seen to much it won't do and once you're used to it, you'll wonder how you ever lived with out it. Plus Ralf is great in the support area should you have a problem. If the item can handle/use the morph MC can do the rest. The manual is "tricky" but its the best 20 bux you'll spend on a tool IMHO.
Thread: Mystery thumbnail | Forum: Poser - OFFICIAL
Well since the chorus has started, sign me up for the No Thumb, No Way.....since I just left the free section, and darn if I feel almost the same with "Site Registration Required". But thats just me.
Thread: Scandinavian Furniture? | Forum: Poser - OFFICIAL
Couldn't you check the runtime folder you down loaded for the appropriate locations and entries?
Perhaps you've got some textures and were expecting a character or prop or vice versa???
Just did that my self recently and went back to the original file to see what exactly was in there.
What I was expecting was not there, so hence, I couldn't find it in my runtime. I would guess the
read me would give a file and location listing also.
While I'm here, want to say thanx for doing some "interesting" freebies. Good Stuff.......
And thanx to some nice staff person who helped me straighten that out.......
HD.
Thread: need help here please. | Forum: Poser - OFFICIAL
On the lighter side........thats cool about the "no obligation to read it", I'm only able to catch part of it anyway. Otherwise I would be in trouble.......
Thread: OT: Cancel your Credit Cards Before You Die | Forum: Poser - OFFICIAL
If I recall correctly from "Financial Peace University" (Dave Ramsey), if your name is not on the contract you are under any legal or financial obligation. If my Mom passes away (example) they can call me (nearest living relative) all they want, if they can find me. Its unsecured debt. I did not sign for didley. Luckily Mom followed my advice several years ago and became debt free as I have been for 12 years. Got the house paid off in 2007 (Chugged down a 30 year mortgage with some re-fi in 17.5 years.....do the math) Never again will I have a credit card. Debt free makes being unemployed a lot easier. I don't need a bailout. But send cash to PO Box xyz123....to quote Daves radio show "Cash is king....Debt is dumb". And didn't Citibank get some of my tax dollars, er bailout money??? There's a pattern here and its a sad one.......Ask any of my "living large" friends who don't answer the phone for fear of it being a bill collector. Its gotten to embarressing to visit some folks. Act your age, live your wage. My 2 cents in cash, paid in full
Thread: Morph Removal | Forum: Poser - OFFICIAL
Thanx all for your replies.
SVDL, I'll look into your script in a sec. Sounds pretty neat.
Momodot, thanx, thats a neat tip also. D3D does some good stuff.
PJZ99, yes, my early attempts did mangle V4 beyond belief, it took a while to figure "her" out but I finally got it after much trial and error and I just left "leg scaling" in.
So I guess I'm on the right track??? With P5 and gen3 girls I did seem to be able to get a lil bit more into/out of a render and firefly did appreciate it. Just didn't know if with P6 and V4 it was worth the effort. I should've asked sometime ago. Better late than never.
Well a Comcast van is still on my street, don't know if this is a good sign or not, we'll see.
Wish me/them luck, hahaha. Thanx again all........
Thread: Poser genitalia m4 | Forum: Poser - OFFICIAL
There is a product for M3 at Daz (go figure) called BAM3 by Uzilite. Nice set of clothes but the undies have some morphs that, er, lets say, that show M3 is an "excitable boy" (Apologies to Warren Zevon). I have managed to transfer these morphs to different pants for a more realistic look under the right circumstance. The morphs will also transfer to M3 for the same situation if a "skin suit" is used but a normal M3 texture will look like he should have had a biopsy run on that bump a long time ago. If you texture M3 at the hips with "cloth" it adds a bit of possible realism with a few tweaks. Throw in a magnet at the right spot and any Super Hero in a "skin tight costume" will volunteer to rescue V3 from impending doom, perils of darkness, high gas prices, or cheap dates. Even tight spandex shouldn't show completly flat in the hip area but thats my opinion. A "Ken" doll doesn't cut it. Right Barbie??? Barbie??? I'm over here..........HD
Thread: Emergency sale | Forum: Poser - OFFICIAL
