4 threads found!
Icee | 6 | 37 | ||
Icee | 19 | 66 | ||
Icee | 4 | 17 | ||
Icee | 14 | 40 |
16 comments found!
Thread: Help with armor | Forum: Poser - OFFICIAL
Thread: help! importing People to Bryce! | Forum: Poser - OFFICIAL
Attached Link: http://www.tabolton.cwc.net/tutorials/tut_vtb1.htm#Stage1
Here is a little tutorial on how to bring victoria into bryce from poser. This will work for any of the poser items& characters you have. Here is the url: http://www.tabolton.cwc.net/tutorials/tut_vtb1.htm#Stage1 Hope this helpsThread: Cr2 Trouble Again AGGGGGG!!!!!!!! | Forum: Poser - OFFICIAL
Ahhhhhh. Now i see.(Light bulb pops up) Ok i have been going about this thing all wrong. This is what I have been doing. Export the Poser default Fig from poser(ie creating a fig. and then exporting it in poser as an obj. Ok once I have this done I now imported it into rhino(modeler of choice) and built the armor around this fig. Then I edited the cr2 as in previous instructions. Then I put the cr2 into the poser dir. and the obj armor into the geometry folder. Ok Then I fired up poser and boom. Nothing. see the screen shop above last one. The way I read your instructions above. What I need to do is rotate the armor obj -90 on the x plane in 3d explorer. This should align the armor correctly in poser. Ok What do I do next. Im kinda confused after that process. How are you getting the poser base obj file into poser are you importing it? If you are clicking on the menu bar I get nothing. Somehow something I edit in the cr2 is wrong. Also how are you getting the armor into poser? Also did i name all the parts right in the obj file ?
Ok Phil I sent you the files. Can you do me a favor and show me where the problems are with a screen shot. It might be easier for me that way. Thanks man Ill get this yet
Thread: Animated clothing??? | Forum: Poser - OFFICIAL
It can be done but it is really tough to do. Creating a poser fig that looks like a certain person is really tough. There are some pretty good modelers on this board that have done some celb look alikes but I wouldn't even try it. Check out morphworld for character morphs. This might be a start. Second, building cloths are a real trouble. Im trying to learn it right now and it isn't easy. Most cloths can be recreated with clothing that is trans and tex maped. If you are looking for a karate suit check out Poserworld. I think on their second cd the have a kunf fu uniform or it might be free in the clothing section. Hope this Helps. Good luck and keep on it. Poser is a great program.
I thought of that as well. I get no listing at the buttom of the screen showing that the object is even there. Ill pan out and see if I can see the object. Thanks for all your help and support
Ok, I double checked to make sure I got the naming right, ie case sensitive like last time Jim. Naming is correct. The problem Iam having is that I can't get it to import into poser. When i try to add the model into poser work environment it comes up blank. The last time I tried this the problem was that I had the wrong naming Head instead of head(case sensitive). Checked it this time and it is ok and im still not getting the model to import. Does this have somthing to do with the .obj file? I checked the figres path and made sure this was correct as well. Thank you so much for your help guys. Hope I can pay you back someday.
Thread: Need Help with COnforming Clothes | Forum: Poser - OFFICIAL
Man I must dummer than dirt. Did everything you said and still don't work. I don't know what Im doing wrong. I don't have the uneck but I do have the neck. By the way why are your numbers in the cr2 different than mine. I get the object to appear in poser but when I click on it nothing happens. Everything is empty
Thread: Hey, it works! A reverse conforming bicyle (350k GIF) | Forum: Poser - OFFICIAL
