33 threads found!
JDexter | 10 | 46 | ||
JDexter | 7 | 33 | ||
JDexter | 0 | 31 |
(none)
JDexter | 3 | 104 | ||
JDexter | 15 | 368 | ||
JDexter | 0 | 73 |
(none)
JDexter | 0 | 106 |
(none)
JDexter | 1 | 146 | ||
JDexter | 39 | 854 | ||
JDexter | 1 | 114 | ||
JDexter | 24 | 718 | ||
JDexter | 10 | 265 | ||
JDexter | 6 | 224 | ||
JDexter | 11 | 272 | ||
JDexter | 2 | 180 |
257 comments found!
Oh, the breakdown is: Lowcut Styles for Michael (Hair) Jose M3 (Texture) BA Boots for David Cargo Shorts for M3 Safari Shirt for David JDexter
Thread: Which model is this? | Forum: Poser - OFFICIAL
Onimusha has it!
It's Hiro.
With clothes from just about everyone ;)
JDexter
Message edited on: 07/14/2005 06:41
Bedtime for me. I'll log in when I get to work in the early am (6-ish CDT) and post who it is. Meanwhile, not Don nor James. :) JDexter
Thread: Clothes Converter 2.2 | Forum: Poser - OFFICIAL
That's odd. The only time I got the ball o' mess was when using an odd donor. I'll give a M3/David a try and let you know what happens. JDexter
What are you using for a donor? If there is a blank available or another piece of clothing that was made for the figure you are working with, use that as a donor. I use A3 blank most of the time when working with A3, and on the Aeon figures, I just use the base figure. JDexter
Thread: David Hair conversion kit by Netherworks | Forum: Poser - OFFICIAL
Thread: THANK YOU PHILC........ FOR WARDROBE WIZARD!!!! | Forum: Poser - OFFICIAL
Thread: New monitor, awful colors | Forum: Photography
It has to be the new monitor. I can subdue ther colors, but only by turning the seperate gamma colors down to the lowest settings, and it still is not good. On Monday, i will swap it with the one in the office to see for sure before I send it back. In the meantime, I'm on a smaller, tube monitor and it is just perfect (though smaller than my old eyes like ;) ) JDexter
I bet it is the Adobe thing. I totally forgot about the ooriginal profile. I bet that will do the trick. The computer at work never had a different monitor, but the home machine did, I bet that's the reason they look so different. Thanks for that. I'll be adjusting it as soon as I get home. I'll let you know if that's the reason. JDexter
Thread: P6 SR1Bug - Goes Wacko When Trying to Export | Forum: Poser - OFFICIAL
Just yesterday I exported every part of a figure, one at a time, so I could loadit up as morph targets on another Unimesh figure. It worked perfectly for me, and that was a lot of parts! After rebooting, are the menus still disabled? Have you tried with a different figure also yet? JDexter
Thread: Hiro armour on Aiko3? | Forum: Poser - OFFICIAL
YOu could also use Clothing Converter at Daz. Since both are millenium figures, auto-convert would work great on it. JDexter
Thread: M3 morphs on David | Forum: Poser - OFFICIAL
Well, talk about timing! I just came on to see if there were any replies and what do you think the banner was for? The UMT. Got my answer now. JDexter
Thread: Anybody tried creating Poser morphs using Hexagon yet? | Forum: Poser - OFFICIAL
Well, I was morphing Laroo's head in the above example, and she does have groups in her face. I had no issues whatsoever with the lip morphs I created, nor any other ones, except that I did an awful job with some of them, which was my lack of talent and not the program ;) JDexter
I use it successfully for Poser Morphs. Here is a quick and dirty rundown of how to do it successfully (and I am no pro by any means, just trial and errored it)
Before exporting from Poser, remove any textures from the model, especially transparancy. Hexagon freezes or just gets so slow as to look like its frozen. Don't need them anyway for morphs.
Leave the import scale at the default 1.0. I have not been able to successfully rescale it back down to keep from the head-exploding problem on usage in Poser if I scale it when importing into Hexagon.
Soft-Selection does not store more than 2 decimal places, so initially turn it off and set it to 0. I will outline below how to use it and it works perfectly on Poser morphs, the problem is the tiny size of the Poser models.
How to use Soft Selection effectively in Hexagon for Poser Morphs.
Set Soft-Select off and set to 0.
Select the main pieces you want (which you will want to soft select around). Doesn't matter if it is Edge, Face, or Vertice, just select the area ones you want.
After you have the things you want selected, turn on Soft Select and put in a value for the area you want soft-selected. Since Poser is so tiny, .001 is the nearest, and .009 is a large area. I usually use .002.
All you stuff will be soft selected at that point just perfectly. If you want to add more base points to soft select around, first set the soft select size to 0, add the new points, then set the soft select to the area size you want again.
The problem here is that Hexagon looks like it stores only 2 decimal places,but it does accept at least 4 decimal places that I know of, and since you need the 3rd place because of the Poser size, it makes for poor selection if you leave it on initially.
If I can think of any of the other things I am doing that might help, I'll pass them on.
Hope that helps,
JDexter
Message edited on: 05/12/2005 09:50
Thread: Hexagon is now available. | Forum: Carrara
Jack,
I can't find any group at all at Yahoo that you mentioned. Search on Hexagon and Eovia. Only turns up Carrara, Amapi, and Raydream.
JDexter Edit:Found it. Got a direct link to it from 3dxtract. Weird that you can't go to Yahoo Groups and just search for it. I never was a fan of Yahoo though. Thanks for the info.
Message edited on: 05/11/2005 07:15
