6 threads found!
JJNorton | 8 | 81 | ||
JJNorton | 2 | 21 | ||
JJNorton | 3 | 72 | ||
JJNorton | 3 | 132 | ||
JJNorton | 5 | 137 | ||
JJNorton | 3 | 85 |
10 comments found!
I found if I toss a few out, I can get down to the plugs starting with "Y", so apparently there is a limit and using the optional plugin directory doesn't help.
Thread: Limit on number of Plugins/Filters? CS2 | Forum: Photoshop
Well that's a no-brainer. I can't scroll down using the arrow past files starting with "Ph*". I can scroll for a bit, but it stops at "Ph*".
Doesn't help here Lou. Thanks for the help, but I'm not beating my head against the wall on this one. I was just curious if anyone else has expereienced the issue or know why it occours. I think part of the problem lies in developers of some plugs don't bundle all effects into one .8bf file, but seperate them so the list grows longer. I can trim some fat though. When CS came out, I liked having PS7 loaded with the plugins and custom effects I use, and also having a clean CS for quick fixes and enhanced use. C'mon CS3!!!
Well I am strictly referring to installing 3rd party plugins and filters, not brushes, patterns, styles, etc... ( I do realize that complex layer styles appended is a real load time killer!). But clicking on the arrow from the Filters dropdown, won't go past "Ph*". If say I install another plugin beginning in "R", I probably wouldn't be able to scroll down past "Pa*". It appears as though there is a limit, however I can't find any documentation of the fact. I realize I could probably spend some time and trim some fat, but just curious if anyones knows of a limit or not.
Thread: Color Matching issue...Color Settings perhaps...? | Forum: Photoshop
Thread: hurricane pic (probably from NASA) | Forum: Photography
Thread: Scratch Disk & Memory allocation question - PS7 | Forum: Photoshop
Thanks for the reply. I just changed settings around a bit and will see how it works. Maybe I will just install another copy that is bare so I don't have to wait 5 minutes to load just for some quick color adjustments. I have XP Pro and it definitely handles memory much more reliably and efficiently. I'd be dead in the water if I still suffered with ME...LOL :?)
Thread: Ultra Fractal 3 Tutorials? | Forum: Fractals
Thread: Uniform placement of objects? | Forum: Bryce
Thread: Liquid in a Container | Forum: Bryce
Select the negative object used to create the empty space inside the glass. Duplicate it and make it positive. Create a cube and stretch it out to extend past the X and Z axis of the sphere and lower the y position to the desired level and make negative. Group them together and make positive. Now apply your liquid material of your choice.
