2 threads found!
Jenjen | 7 | 163 | ||
Jenjen | 13 | 293 |
8 comments found!
OK, a bit late to the party, but .. I'm honored that the staff would consider one of my images good enough to be a pick. :blushing: Thanks!
Thread: V4 finger and neck lockup | Forum: Poser - OFFICIAL
Well, the only way I know of to get to the attribute in question is to use an UnHide Dials python script. I've tested that out and by unhiding the dial in question, I can also correct the problem. In the hand it is an attribute called INVThreeFinger, and in the neck it is INVHideNeck. if it is at 0, the body part is locked, and at 1, it is unlocked.
Just exactly as RHaseltine indicated.
So I have two ways to fix the problem now, the first being just to not Zero the figure, the other to unhide these attributes and reset them to 1.
I wonder too why the lock is at 0!
Figured it out. When I select Zero Figure from the figure menu in PoserPro 2010 Victoria 4.2 and Michael 4 experience neck and finger lockup.
I don't think that is a normal result, so am going to post this at DAZ and Smith Micro.
edit: Using Zero Rotations from the Joint Editor window works with no problems or joint lockup.
Thread: Poser 8 | Forum: Poser - OFFICIAL
And a new question. How well does Poser 8 play with the new Windows 7 system? Hubbie is about to upgrade Windows and I currently have Poser 6. He is considering upgrading my Poser at the same time. Has anyone yet had any issues with either version of Poser under the new Windows system?
Thread: Renderosity FreeStuff - Allow External Hosting Petition | Forum: Freestuff
Thread: What happened? | Forum: Community Center
That is exactly what happened. Tried again and it posted right up! :)
Thanks again for the responses.
Thread: Poser Staff Picks (01/18) | Forum: Poser - OFFICIAL
