5 threads found!
JerryLee | 2 | 17 | ||
JerryLee | 5 | 34 | ||
JerryLee | 4 | 18 | ||
JerryLee | 10 | 35 | ||
JerryLee | 3 | 15 |
2000 Mar 06 3:44 PM
11 comments found!
well dont ask me what it all is...lol..what I can tell u is if u want to make a morph for a body part export with the option 'As Morph Target' select..prurdy obvious huh? ;) For export to Bryce I use 'Include figure names in polygon groups'and 'weld body part seams'..for clothing I suggest u use only the first option. Not much of an explanation but it gets the job done ;) -Jerry-
Thread: Eve V3 eye problem | Forum: Poser - OFFICIAL
I got it guys...thnx...tho there was no such texture, the eyeballs needed a seperate texture too. -Jerry-
Thread: To all you morph-masters out there... | Forum: Poser - OFFICIAL
Thread: Aaaargh! | Forum: Poser - OFFICIAL
I have no idea how to solve this..but please do post her! I have seen many tries for recreating ppls in poser..urs is SO VERY good!
Thread: New Prop Available For Download | Forum: Poser - OFFICIAL
Thread: extremely hi detailed face textures | Forum: Poser - OFFICIAL
I think Allerleirauh is right...make the texture bigger. If u wanna do closeups in poser the image used for texture is stretched out since the map is 950x950 pixels.. However scaling it will stretch the picture also, so u prolly have to redo it a bit in order to get some detail. Just make sure u keep the proportions of the picture..
Thread: New natural hairmap | Forum: Poser - OFFICIAL
well I rebuild the map for this prop in UVmapper...took me 3 days to get it as flat as possible. The only thing that would make it a better map is if I could unwrap the edges..like the map of the poser models are done. The tail for instance is distorted because the map has parts of the prop hidden behind other parts
Hmmm that might have something to do with the way I saved it ...to get a good preview in the library.. There was a character under that hair, so urs prolly takes over the expression from mine..(wich was none) It prolly helps to save the expression from ur character before u put on the hair..than put the face back on. I know thats kinda a long way to use it..so I look into it
Thnx ;) It still has distortion on the back tho...but I'm getting purdy dang close.. It would very much help me if someone could explain how to unwrap the UVmap in Max..
Thread: Flat UVmap for hairprops | Forum: Poser - OFFICIAL
Thread: Now, what's all this then? | Forum: Poser - OFFICIAL
