We couldn't find any threads matching the specified search criteria.
7 comments found!
I understand what you want. example: Morph 1 Curved down blade Morph 2 Curved up blade The normal way to do this is to make 2 dials, but to only make one dial. Use the Curved down blade as base geometry and then add the curve up blade to it, a strait blade should be somewere around .5 on the morph dial. Provided you curved the blade down the same amount you curved it up. Try it. Karl
Thread: how to put a real photo into poser?? | Forum: Poser - OFFICIAL
Thread: Attn:Renapd-Leona & Posette? | Forum: Poser - OFFICIAL
All I wanted to say was thanks to the givers like Rena, Steve and many others. Because of what they produce we the takers actually have something to take for free. No charge, no cost, not even a thank you note is needed to get some first class addons to Poser. As the Poser3 figures replaced the Poser2 ones, Possette has replaced Poser3, and now Vickie replaces Possette, this time next year something will replace Vickie, For those on a budget you will be one version behind the rest. Karl
Thread: Lightning problem | Forum: Poser - OFFICIAL
I think you are using the default Colored lights. Use white lights. Make all lights grayscale lights. 0,0,0 to 256,256,256. Should fix your problem. Karl
Thread: The Nasty Tech at CuriousLabs | Forum: Poser - OFFICIAL
I have read all of the above and found it interesting. Artist3D, you have asked a question for which there is no right or wrong answer. Each compressor used in poser has an advantage and dis-advantage. The number od compressor options you have on you computer is different than everyone elses, the compressorors have to be loaded so all computers are not the same. I read you first post and noticed right away that you did NOT post the first responce from the Tech. Why? It would appear that more and more of this comunity want things handed to them on a silver plate, one button click and demand that everyone servise them and there needs. Hmmmm sounds like 1984 comes to reality. Karl.
Thread: Poser animation render hang ups continue =( | Forum: Poser - OFFICIAL
Grook: Turn the BUMP maps off or take them out of each figure. This is an old problem with Poser dateing back to poser3. For some reason the rendering of bump maps totally screwes up the animation and causes the computer to lock up. I have rendered 900 frame animation with no problem. As long as the bump map option is turned off. If left on I get about 150frames then crash. The other option is to render to frames, this way when it locks up you just start the render from the last frame. BUt there are problems with this as well. only being able to render 255 frames at a time before crashing. Good luck Karl
Thread: Vicky....Or maybe we should call her Barbie 2!!! | Forum: Poser - OFFICIAL
I just wanted to make a comment about the chart from Bast. The assumtion you have made is the the things in the free stuff pages are actually free.... Wrong. Everything I have ever downloaded had some kind of a restriction for use or a clause that "if you make money from this then it is Mine statement." So I Download, I look , I read , I delete. So few things are truly free. Thanks to all the people who have post "FreeStuff" and thanks also to the many posters of "RestrictedStuff". If not for all the givers there would be nothing for the takers to take. I have purchased many a model from Zygote and plan to buy many more, to me they are a real bargain.
Thread: Making a "two-way" morph? | Forum: Poser - OFFICIAL
