8 threads found!
Maira | 1 | 64 | ||
Maira | 13 | 635 | ||
Maira | 0 | 46 |
(none)
Maira | 2 | 160 | ||
Maira | 2 | 82 | ||
Maira | 2 | 149 | ||
Advisories: nudity
Maira | 2 | 146 | |
Maira | 0 | 46 |
(none)
27 comments found!
What gryffnn said. Set the eyebrows material color to the same color you have set for the head and body. This will fix the problem.
Thread: Does anyone know if Poser 5 is out April 1 or is it a fools day joke | Forum: Poser - OFFICIAL
Thread: New FREEBIE at Libra Studios | Forum: Poser - OFFICIAL
Thank you all, folks! I think I can go to bed now. It's 7.20am already! When I wake up, I'll try to find a permanent solution for this problem. :-)
Sandy, thanks for your input! I tend to believe that it must be a cache problem. In any case, I'll try to find out soon.
Sorry for the problems, guys. I'm trying to find out what's wrong as I have other freebies on the way and I wouldn't want anybody to have problems downloading them. ---------------------- Ronknights, have you visited the download area at Libra-Studios in the last 5 days to download something else? Like the 10 Poses for Victoria? If you have, could you try again after cleaning your cache and see if you can view it? It mustn't be your configuration as my fiance has exactly the same and he can view the page. ---------------------- RonGC, thank you so much for posting the problem you had at the Libra-Studios forum. I posted another link for you there to see if you can view it without problems. ---------------------- Thank you all for your help :-) Maira
Thread: Rendering problems | Forum: Poser - OFFICIAL
After I got rid of the useless files in my libraries, I now have a little over 2GB of freespace. I think it's enough for swap files, isn't it?
I'm on Win98SE and I didn't have any problems of the sort until a couple of months ago. The problem deteriorated during the last month and I had to re-install Poser 4 after I had deleted all the libraries. After I re-installed it, I deleted the default libraries and installed only the stuff that I actually use. Poser 4 seems to work better now but it still hangs more often than 3 months ago. I'm not sure it's an OS problem as it used to work just fine in the past. If anybody knows the answer, please tell us! :-)
Why is it not showing? If you have visited Libra-Studios recently, then you probably need to hit the refresh button. If any of you have problems downloading any file from the freestuff, please post a message in the Freebies Forum at Libra-Studios.com, stating the exact problem as well as what browser you are using and what version it is.
Thread: Free Model this week - ready now... | Forum: Poser - OFFICIAL
Thread: Last question for a while I promise!!! | Forum: Poser - OFFICIAL
Attached Link: http://www.libra-studios.com
I agree with serpentis. Her arm doesn't real that bad and you can always do some postwork to eliminate those poser artifacts. :-)Thread: New CONTEST! | Forum: Poser - OFFICIAL
Thread: New CONTEST! | Forum: Contest Announcements
Thread: Vicki eyebrow problem - strange | Forum: Poser - OFFICIAL
It seems like the underlying object color for the eybrows and the face are different. Make also sure that the ambient color is the same as the face. Sometimes one of the two is pure black and the other is a very dark brown, so it's impossible to see the difference, that's why I suggest you set the ambience manually, for both of them.
Thread: Does anyone recognize this actor? | Forum: Poser - OFFICIAL
Thread: Eyebrow question - PLEASE HELP | Forum: Poser - OFFICIAL
