1 threads found!
Posted Sep 26, 2019 at 3:58 pm | Forum: Poser - OFFICIAL |
MartyJohn | 17 | 362 |
5 comments found!
Thanks again for the welcomes, much appreciated.
What I would like to see from Poser going forward.
Alembic import.
I think it would be great having this option. This would enable artists to import simulation cache data for starters.
On a more Poser level playing field it would enable us to import simulation data straight from Marvelous Designer and object meshes too. Another benefit to alembic is that it will import curves as well, so if you created hair strands in another package they would come in with the alembic data.
With ZBrush I seem to have a limit of only being able to import a certain amount of hairs per object from GoZ no matter what density settings I use.
Cheers
Thread: Hello and thankyou from a new member | Forum: Poser - OFFICIAL
Hey thanks for all the welcomes!!!
I also own IClone 7 and CC3.
My first tip of the day. You can import CC3 actors into Poser if you want. The .fbx files import them weird, the head looks like it's snapped and everything is out of whack.
The issue is with the parenting. Each separate object is parented to the wrong object when imported. They come in with eyes, tongue and teeth all parented to the wrong object. Re parent each object back to the main root bone or body and then it all works fine.
You can't set up IK as far as I can see due to the roll joints interfering with the bone order when selecting the leg to foot.
You can use simple skin weights rather than uni-mesh and you can pose and select your characters using the direct manipulation select each body part.
Have fun :D
Cheers thanks a lot.
I'm hoping to get involved and help others as well as maybe provide some assets myself. :D
Here is another one, cheers for the new figures and all the vendor content added, your stars. :D
