4 threads found!
Melisand | 0 | 125 |
(none)
Melisand | 6 | 181 | ||
Melisand | 1 | 33 | ||
Melisand | 1 | 58 |
11 comments found!
Quote - and you tried re-exporting from Pose2Lux?
I tried creating a very simple scene.. opened the script saved and then.. open lux and same error.. don't know what I'm doing wrong..
Thread: Pose2Lux | Forum: Poser - OFFICIAL
Quote - > Quote - Did you try opening it again? Sometimes if you load twice, it loads the second time.
Â
Ok will do that.. thanks Laurie..
Â
same error unfortunately..
Â
Quote - Poser Pro launches scripts thru the scripts window, like Poser 8 and Poser 7.
Ok thanx for reminding me however.. when I opened lux to render my saved exported scene I get this error..
Â
[2011-03-13 23:52:41 Severe error: 47] Parsing error in file 'MyLuxScene.lxs' at line 16: syntax error
Quote - > Quote - how do u launch pose2lux?
Just like you do any other python script if you use Poser 7 and up.
If you're using Poser 6, when you goto open a Py file, the file box won't see the pyc. so you can put in *.pyc and enter, and you'll then see it in the file list or just put Pose2lux.pyc in the file name box and call it that way. To find it, you need to migrate to the folder where you placed the Pose2Lux script.
Pose2Lux does not work in Poser versions prior to Poser version 6.
Â
I use poser pro 2010.. forgive my blank moments...
Thread: How Do You Use the Depth of Field option in Poser Pro? | Forum: Poser - OFFICIAL
Quote - You need to use the "focus distance guide" from the "display" menu (under "guides"). Then select the camera and play with the focus_Distance parameter.
Using a z-depth render to post work is probably better as that gives you more control.
ooh... thank u !!
Quote - turn on the Depth of Field marker in show guides - this will be your focal plane.
select the camera, there you'll see a dial that moves the Marker to/from the camera.
set Depth of Field on render options.done!
wow. .thank u for such a speedy response!!! I appreciate it very much!!!
Thread: Problem with order # 111307264 | Forum: MarketPlace Customers
Thread: Problem with the gift certificate | Forum: MarketPlace Customers
hey Im looking for the link for my purchase with the gift certifcate as well
"Thanks for your order (111307264) on Renderosity.com.
You will receive another email regarding payment.
Please see order details below:
Sub-Total: $ 0
Shipping: $ 0
Taxes: $ 0.00
Total: $ 0.00"
That's all i got.. please help..
Thread: Yet another V4 morph - Opinions wanted | Forum: Poser - OFFICIAL
