2 threads found!
MrFiddles22 | 5 | 516 | ||
MrFiddles22 | 16 | 792 |
17 comments found!
Smaker1 posted at 3:41AM Sun, 10 December 2017 - #4319831
Hello
what hair is it? did you also installed the bridge patch made by Philippe? See in the VWD forum "Daz studio 4.10 (rollback)" second page
It's also better to post in the VWD dedicated forum
Thanks. It looks like it's fixed with the latest DAZ 4.10.0.123 Version. And thanks for pointing out that post. I'm pretty sure DAZ's OBJ export issue was causing the my problem.
Thread: Hair Texture Issue After Conversion in VWD, Daz 3d | Forum: DAZ|Studio
Smaker1 posted at 2:10AM Sun, 10 December 2017 - #4319831
Hello
I looked for the dedicated forum and must have missed it.
Yes the Daz bridge extension is installed every thing works normally, just like when I used it in poser a while back.
I tried several Daz hairs and had the same issue "Spring Hair" and "PH Timeless"
What version number of VWD are you using?
Thread: Conforming clothes and hair animation | Forum: Poser - OFFICIAL
@VitrualWorldDynamics Keep working at it, have faith you will get it all sorted out ready for release. Just focus on what Renderosity wants to get it to pass, and then continue polishing it up later. Continue to offer it as a BETA version so you can continue to get paid.
Suggestion: You can add a "PayPal Tip Jar" or "Pay Pal Donation Link" in the information section of your YouTube videos for people who want to support you, my friend does this with her YouTube channel and she gets a little money here and there.
I agree with @Biscuits, this is one of the best plugins to come along for Poser. Gerard is a genius! It is definitely much faster than Poser's cloth room, and less forgiving of intersecting vertices and edges. I want this plugin to be around and available for the foreseeable future.
Hi @Biscuits, I have been using "Movavi Screen Capture" It works fairly decently for me. It can convert your screen capture to video via AVI or Mp4 and other formats, you can also add subtitles, it cost $49.00 USD. Link: Movavi Screen Capture
Biscuits posted at 5:08PM Mon, 07 March 2016 - #4259489
I never dare to touch camstudio again, I tried it before and my av/malwaresoftware went wild on it.
Any other options?
@Vestmann
Thanks for the reply Vestmann,
It turns out it was a simple mistake.
@VirtualWorldDynamics said the "exe" file (The program itself) he sent out was incorrectly named, and had to be manually changed.
It was named incorrectly: VWCClothAndHair
When instead it should have been: VWDClothAndHair
So Poser could not find it when trying to launch it. I simply just changed the name to the correct one and it works now,...JOY!!!
Thanks for the offer of help! :-)
Gerard, If you could make a future consideration for a video or manual, that shows exactly how to properly set up the VWD folders, what's needed, where to get it, and how to install it, that would be greatly appreciated. I remember when I first tried the program a few months ago out it took me several hours of folder and file trouble shooting before I got the program to work correctly. Thanks for your help
I took some time to try out the latest VWD version that you sent out last week, but I am unable to get it to work. I tried replacing the old version by swapping it out and installing the new one in my VWD folder, but it just leads to an error box popping up (See Below)
I also noticed there were new script buttons for the new version that were not in in my current VWD folder, so I got the new ones by downloading the Demo version from your free item page and adding them to the Poser VDW folder as well.
The VWD program opens up fine on its own but wont open when trying to through Poser 11.
I'm not really sure if this was the correct way to do it. Help would be appreciated. (I'm using Poser Pro 11, 64Bit/ Windows 8)
Error Box
This is how my files are set up
That's great news Gerard! Thanks for the update!
The videos you made were extremely helpful for a visual learner like myself, I was able to use the plugin after only watching the video a couple of times.
I know making tutorials can be tiring and time consuming. Maybe consider "quick and dirty" videos showing quick concise specifics of the most important processes, with paraphrased subtitled explanations may be easier for you to produce and edit, then consider adding advanced tutorials at a later date.
This way, when you release the Plugin people can get started out properly and hopefully not be sending you questions all day long.
I appreciate all your effort you put into this Plugin! Thanks Again ;-)
@VirtualWorldDynamics: Thanks Gerard, I wanted to suggest the possibility of a "Transferable License" idea to the list of requests for your consideration. It's a great plugin, you are doing an amazing job, I'm eager to test the final version...Thanks again
@shedofjoy: Thanks for letting me know
Vestmann posted at 4:12PM Fri, 29 January 2016 - #4251957
MrFiddles22 posted at 2:46PM Fri, 29 January 2016 - #4251940
Hi Gerard, @VirtualWorldDynamics
A couple of questions:
-Have you tested this Plugin with Windows 10 and Poser 11? (I want to upgrade to Windows 10)
-Any future plans to have a plugin serial number that is not tied to the computer, but is transferable? (In case I want to change computers and by chance if you discontinue support for the plugin)
Thanks
I'm running the program on Windows 10 and Poser 11 Pro without a problem.
Great! I want to get the free Windows 10 upgrade before it expires. Thanks @Vestmann for letting me know.
Thanks
Wow! this plugin is cool!!! I just found out about it, Is it for sale yet? If not what is your planned timeline for release? I have been searching the internet for some kind of easy dynamic hair solution, I need a plugin like this for a project I'm doing. I need something like this as soon as possible! I'm using Poser Pro 11 on Windows 8. If you sell on Renderosity that would be great! If not, I have no problem paying with Pay Pal. Hopefully the license will allow for use on at least two computers that would be helpfull, because I use two computers in my current workflow.
Thread: Victoria 4.2 eyes wont close or open??? | Forum: Poser - OFFICIAL
Quote - > head scr'ch ... i don't understand how the library figure can be broken.
I know. Weird, but seems to happen to lots of people.
I saw this too, I looked over the post again, and tried editing the dependencies
Tell me if you want to help to get that inject script to fix it
If you have somthing that helps, that would be great. Is the script a custom one you made?
Quote - The solution is discussed here on this RDNA thread:
http://forum.runtimedna.com/archive/index.php/t-64299.html
I saw this too, I looked over the post again, and tried editing the dependencies. It seems to work, but needs some tweaking. I'll have to test it out. I'll guess editing the dependencies is the best option for now if you want to have the morphs++ file installed and eyes blink. Thanks.
