DAZ|Studio F.A.Q (Last Updated: 2025 Jan 19 2:48 pm)
Smaker1 posted at 2:10AM Sun, 10 December 2017 - #4319831
Hello
what hair is it? did you also installed the bridge patch made by Philippe? See in the VWD forum "Daz studio 4.10 (rollback)" second page
It's also better to post in the VWD dedicated forum
I looked for the dedicated forum and must have missed it.
Yes the Daz bridge extension is installed every thing works normally, just like when I used it in poser a while back.
I tried several Daz hairs and had the same issue "Spring Hair" and "PH Timeless"
What version number of VWD are you using?
Smaker1 posted at 3:41AM Sun, 10 December 2017 - #4319831
Hello
Thanks. It looks like it's fixed with the latest DAZ 4.10.0.123 Version. And thanks for pointing out that post. I'm pretty sure DAZ's OBJ export issue was causing the my problem.
I'm using VWD for the first time in Daz 3D. After converting the hair in VWD the textures look like this (See picture) Is there a fix or setting for this?
I may be using an old version of the plugin V1.1.522.3630.Can somebody confirm if there is a newer version available?
