14 threads found!
Myrailon | 0 | 816 |
(none)
Myrailon | 5 | 506 | ||
Myrailon | 4 | 179 | ||
Myrailon | 2 | 181 | ||
Myrailon | 1 | 195 | ||
Myrailon | 8 | 389 | ||
Myrailon | 7 | 181 | ||
Myrailon | 12 | 1848 | ||
Myrailon | 1 | 55 | ||
Myrailon | 60 | 5329 | |
Myrailon | 3 | 1027 | ||
Myrailon | 6 | 202 | ||
Myrailon | 2 | 2252 | ||
Myrailon | 9 | 232 |
9 comments found!
thank you all. I changed the frame count (and it deleted the animation), I selected the path from the prop list and deleted it, I clicked at zero rotations in the joint editor (didn't make any difference, it was at zero) and I selected the base layer in the animation palette (it was selected). But if I add a pose, the model rests as it was, only the clothes are getting rumpled (see attachment). It seems as if the pose only affects the clothes, though in the hierarchy editor, I put them into the model right in the chest's tree. And, of course, I selected the whole body of the model.
Roland
Thread: Remove animation, keep frame 1 | Forum: Poser - OFFICIAL
Thanks. This worked, but it's still not possible to edit the pose, bend the legs or add a pose. And the walk path is still visible.
Thread: How to attach clothes and hair correctly? | Forum: Poser - OFFICIAL
Thanks. This works well now with the clothes.
The pony tail (from the content) is attached automatically, so this isn't a problem. I created hair by using a skull cap ( in this case a beard) and this beard won't move with the figure. What's about that? This doesn't work with object -> change parent nor figure -> set figure parent nor Figure > Conform to.
Thread: How to cut single images to a movie? | Forum: Animation
Thanks. Never heard of this tool, but thanks.
I have BMP files and several movies. One has 51+101+23+75 images, the other one has 101, another one has 184. Not very much, but I wanted to have completely uncompressed images for the intermediate step and compress it at the very end.
Thread: What effect does a newer graphic card has? | Forum: Vue
Hi surveyman,
you mean I should downgrade it? Everywhere I'm reading I have to update it. I could take the original driver which Windows wants to install. I had this one and I went better with the newer driver.
Regards
Roland
Thanks for your comments.
I got an info in another forum, that the gpu doesn't make a big difference in rendering anything with Vue, besides OpenGL.
If I switch to wireframe mode option in the settings, Vue is becoming much more stable. As I could see, Vue 8 doesn't has a wireframe mode any more. So I'm afraid of instability. Vue 8 seems to need OpenGL for many features. But it isn't profitable to buy a big graphic card just for this.
What do you say about this?
Greetings
Roland
Thread: freeware converter avi2swf? | Forum: Animation
Thread: Tips For Icebergs?? | Forum: Vue
Which material do you use for ice? If you just take "snow" you'll get nor more than a snowball, but ice has also blue parts.
