75 threads found!
Navim | 5 | 564 | ||
Navim | 7 | 618 | ||
Navim | 7 | 509 | ||
Navim | 1 | 152 | ||
Navim | 4 | 264 | ||
Navim | 0 | 133 |
(none)
Navim | 6 | 530 | ||
Navim | 0 | 290 |
(none)
Navim | 0 | 231 |
(none)
Navim | 31 | 1554 | ||
Navim | 4 | 268 | ||
Navim | 15 | 839 | ||
Navim | 3 | 321 | ||
Navim | 5 | 537 | ||
Navim | 0 | 77 |
(none)
232 comments found!
Thread: Lost my poser serial number | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Exporting from poser | Forum: New Poser Users Help
Thank you, but I have already deleted the model file.Sounds like you have texture plus transparency mapped onto place-holder rectangles. Much, much lower-poly than drawing each leaf's near-fractal detail...
Please check for transparency map(s). If not stand-alone, may be texture's Alpha-channel in PNG, or equivalent in eg DDS.
Free 'Irfan View' is your graphics-format friend...
RedPhantom posted at 7:15 AM Sat, 4 June 2022 - #4439549
Good morning. I tried checking use ftp's as you suggested and the leaves show up as rectangles. I want to thank you for your help but this is just too much time to spend on a model when there are other sources for less expensive models that work. I am going to ask renderosity for a refund and will not purchase any more plants from this vendorWhen you export the tree, check use full texture path in the export options pop up.
Regards,
RedPhantom posted at 9:08 PM Fri, 3 June 2022 - #4439538I checked the file and it is only poser contentI will check to see if an obj is available. Big problem i run into is bryce not asking for any texture file upon opening the obl, Wondering if this requires a reinstall of bryce?I do believe the marketplace requires products to include obj files with all models. You might look in the geometry folder. What format are you exporting to? I've never had any trouble with obj from any version of poser.
Thread: Exporting complete images | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Background images hidden below main window | Forum: Poser 12
Thread: Parent props/clothing | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: useless models | Forum: Poser 12
Just upgraded to vers 12 after much difficulty and find that most of the content including recently purchased items will not load. Under the Purchases tab the download bar goes to 100% and then reverts to the Reinstall bar. This happens repeatedly. Help and suggestions greatly appreciated. I have too much money invested to quit now.
Thread: Clothing not showing in pp11pro | Forum: Poser - OFFICIAL
I'm done with any character associated files from people I don't know period. Some of the older creators can be relied on such as Smay, Renapd,and Littlefox but other than that the only thing I will purchase are objects. But after 25 years of 3d I don't really need any more content. After all it is just the same old ---- on a new character and I am supposed to throe out all of my previously purchased content and buy new versions of it? I don't think so. BTW I have deleted all of the La Femme files from poser and will give any associated products to someone who has the time to fix them.
Well fellas it is very strange that products from xurge and summoner installed via the install from zip function work fine whereas products from 'osity do not. Operator error right? Bull!
