We couldn't find any threads matching the specified search criteria.
13 comments found!
Thread: What were they thinking? | Forum: Poser - OFFICIAL
Ok how the program works is that you need at least 2 image files already
you then use L.I.E to place the tattoo in the position you wish on the torso texture
you then save the file which is just a txt file (if tyou right click and select open you can veiw it in a text editor) like a mat pose and is about 4KB in sizeÂ
all it does is set a path to the two texture(or more)Â used and position etc.
it Does Not create a new image file this is why there is no need for it to have any image format
What is handy about it is I can create an add on for another merchants texture pack i.e adding tattoo's to the skin without needed to add the original textures in the pack I just need to add the .dsi file and my .png files and some DS pose files to apply the .dsi.
Below is the text in a sample .dsi file I made
Â
Â
Â
  /Runtime/textures/ARTCollaborations/Morgaine/2_MorgaineT.jpg
  yes
  2_MorgaineT
 Â
  Â
 Â
 Â
  Â
  Â
  Â
  Â
  Â
  Â
 Â
Â
Â
  C:/Documents and Settings/Neil/Desktop/testing2.tif
  yes
  testing2
 Â
  Â
 Â
 Â
  Â
  Â
  Â
  Â
  Â
  Â
 Â
Â
Â
Thread: And the theme for the May challenge is | Forum: Challenge Arena
Thread: April Theme - Mini-challenge. | Forum: Challenge Arena
Thread: Febuary monthly challenge theme | Forum: Challenge Arena
Rapunzel, Rapunzel let down your hair.
Ouch, you may be a fair prince but you are not a light one.
Thread: HEEEELP!!! Emergency PC help needed. | Forum: Bryce
Attached Link: http://www.tweakhound.com/xp/WindowsXP.htm
After going looking for help on tweeking XP for gaming found this nice site that may help you get your PC up and running properlyThread: HEEEELP!!! Emergency PC help needed. | Forum: Bryce
ok when you get in to the Bios their should be a menu bar across the top with Main, advanced etc you use the left and right curser keys to go to each one if you have one called boot go to it and press enter other wise you have to look in each section for a boot or boot device priority usining the up and down cursor keys enter on the boot section you should get 4 choiuces set 1st to cd/dvd 2nd to fdd 3rd to hdd the save and exit usally f10 some bios are a little diffrent but work the same
If you can have anti v and Firewall on a disk format PC make sure no USB devices conected install XP then anti-v and firewall install dsl and go to WWW.microsoft.com and use windows update it adds about 8 files after the reboot install service pack 2 from cd or windows update after reboot go back to windows updates and get the last updates in between run Adware if you have it (ps may have to disable some firewalls to use windows update) after sp2 is installed go to secuarty center and turn off MS options and use your own. hopfully this helps it will tack you around 3 hours to do all this
Thread: OT - Doh! question about networking 2 pcs. | Forum: Bryce
which eircom one do you have is it the cayman 3300 or a diffrent one here is another suggestion If you pick up a netgear 4 way 10mb Ethernet hub available at Maplins(off heanry street), PC world (Livey vally or Blanchards town) or Harvey Normans(Swords) for about 20 and get two network cables use the network connection wizard in XP and set up a work group but no domain and make sure each pc has a different name allow it to auto detect settings make sure the same work group is set in 98 (right click network neighbourhood) reboot and see it they talk make sure any firewall allows document share over LAN (some times it take 2 or 3 reboots before the comps talk as windows is wacky like that) hope this helps
If you get Broadband from Eircom The Broadband modem is also a hub with one usb and one network conection they are conected and both can use the internet I also use a hub as an uplink of the network conection to enable two win 98 pc to talk to one win 2k PC
Thread: Renderosity FreeStuff - Allow External Hosting Petition | Forum: Freestuff
