1 threads found!
Olivier | 5 | 436 |
116 comments found!
"Attributing the personal attacks that others have made to me when I never said them just shows the levels that Olivier will stoop to ...." blablabla
Learn to read, Mister Mizrael. Learn to read.
I never wrote you said them all. I even never wrote you said one in that particular post.. I just gave clear evidences (do you that word?) that the attacks were really not directed to you and that you were fooling us by playing the role of the victim. Once again, you complain about things that are not connected to reality. That really should alert you at some levels. Because if you can fool yourself so deeply, I doubt you can fool people for a very long time, now.
Why?
Because they can read. And they understand what they read.
Best of all, the more you speak, the more evidences you bring. Thanks! :)
Thread: EF-CP-G2 Promises, Integrity, Honesty and Accusations | Forum: Poser - OFFICIAL
Okay, so it appears that you need things to be spelled in a "primary" way,.
1- You complain about personal attatcks BUT you and your fellows are the ONLY one here attacking (me for instance). Explain this.
2- You complain (again?) about some posts not being contributing. When I read your own (therefore great) posts, I then realize that your way to contribute here is nothing but spitting, reporting corridor noises, spreading rumours, speculating on things you completely ignore. Oh, you're not the only one. But I must admit that in that regard, you're the "best" (which means worst if you understand the context) contributor.
If you still encounter difficulties to understand my point (that is pretty simple finally), no problem: In fact english is not my primary langage but I can make primary enough if needed. :)
"nothing to contribute to the discussion"
I think you're saying that he has no spit on EF or CP, spread rumours or corridor noises, make assumptions on what and how EF and CP do things, or how shameful they were to go to Siggraph, right? ( I won't provide any quote: you just need to read your own posts.)
Indeed he did not have your brilliantly positive attitude. Such a shame.
"personal attacks"
Do you mean things like: "I usually wouldn't touch a merchant with your attitude with a ten foot pole.", or maybe: "Olivier go troll you own boards will ya", or was it "Looks and sounds to me like he's written himself one of those stupid AI Alice Psychiatrist programs that people find amusing in their non-responsive answers. He obviously has nothing to contribute and is somehow amused by his own idiocintricities.", or this one: "Why do I keep being surprised when talented people turn out to also be jerks?"...
So, mister Mizrael, when will you stop playing the role of the victim? When will you stop inducing false statements and a global mispleasant feeling about these 2 companies that do their best for us all? Why don't you search for a more positive way to express what you feel? Are you so bored with life that you can't make it joyful anymore? It is not meant to be insulting. It's just that I really can't understand how you can keep that attitude. Any enlightment from you on this question would be greatly appreciated.
Solution A:
the G2 versions are free for nobody.
Solution B:
The G2 are free only for G1 owners.
Solution C:
The G2 are free only for Passport members
Solution D:
The G2 are free for G1 owners AND Passport members.
CP has opted for solution D. This is THE MOST GENEROUS offer they could seriously make.
Thread: still and again...Poser6 Firefly render problems | Forum: Poser - OFFICIAL
Your frustration is understandable, Nicola.
But don't give up, please!
What intrigues me is the fact that the render can stop randomly even with no light and that it stops without any warning as if it considered it had finished its job...
What kind of things can change from one render to another when the scene is not changed? What could explain that sometimes it works and another time it doesn't? Something related to P6 (necessarily)Â that changes while the rest is unchanged... I'm dry. I need to think more.
Definitely, contact EF.
Do you have screen saver running in background? What are the parameters regarding energy use and finally, what's the temperature of you Motherboard and cpu? Also, have you defragmented you hdd recently?
Sleep well, Nicola. I wish I could have been more efficient. :S
Okay. This scene will be a good test scene.
Here's what I propose you: delete all lights. Then render. Does it work completely?
If yes, then create a new light, an infinite for example. Render. Dooes it render completely?
Once again, if yes, add a second light and so on.
What are the results?
Also, while doing these tests, could you open the task manager and use its graph mode. Look at the cpu and kernel levels (you can activate it via the option of display -> kernel time, I think). When the render fails, do you see a huge increasement in the kernel use? Also, what is the amount of memory used by the Poser.exe process when it fails?
G2 are FREE for passport users.
They DO have morphs, just like the G1 had.
G2 have much better joints than G1.
G2 WORK in the face room (at least James2 does, I've just tested it, not sure for the 2 other guys but that wouldn't surprise me they do).
CP and EF are 2 seperate entities.
CP does not release any product. It's a DISTRIBUTOR.
Just to bring some facts that should have been reported by the so called "victims of Olivier's ugliness".
Now a little example of manipulation, based on the same model as this thread:
"so you see, this whole thread has no other purpose than leading people to feel confused with EF and CP. For what motivations? Well, when you realize that these are the same guys who piss on Daz, RDNA, EF and CP, would it be in this thread or in oprevious ones, you get the picture. In fact these companies share a common point. A coomon issue related to their Lord. See what I mean?"
No proof.
100% bullshit, would I say.
But I'm pretty sure that some of you have some serious doubts now, right?
That's the kind of effects a manipulations can create. And that's exactly what this whole thread is.
And finally, for the guys and gals who wish to tell me they won't buy my stuff because I'm a ugly person that should be burnt in the old fashion, money is not a major goal in life, you know. My only concern is to provide people the perfect tools that can help them making nice pics. If you happen to make nice images and share them with the community, I'll be happy. If you buy my stuff I'll be happy too. If you don't that won't make me sad at all. I hope you can decide what you need to get or do without any childish consideration. Not for my personal business, no. But for your own life, I truly hope so.
I leave you there, folks! Go back to Poser or any other app and make some nice pieces of Art! You'll feel much better! :)
Okay, so I appear to be a "stinky trolling jerk". :D
That's great. So, you had to be 3 to get this? A nice example of collaborative work, really. ;)
Well, I guess this is the fair price to pay for telling some people here that they'd better invest their energy into masteing their tools instead of vomiting all the time on other one's hard works, accusing without prooves, spreading false rumours, manipulating people and making issues for being politely redirected toward a brighter plan of existence... :)
Bah! No harm, folks! I won't make any issue regarding this. I keep issues for the people I care about (you know, those alien stinky trolling jerks who help others from time to time). In your funny lttle gang, I see no one who could ever be worth having any kind of issue. Sorry if that hurts your ego, kids: that was not my intention. :)
God bless you! All! And may He help you to find more constructive ways of expression!
Don't forget to backup some files, such as your emails, addresses, favorites, My Documents, etc.
Have you checked the services in Msconfig? or the list of tasks that open with Windows?
Do you see anything suspect there?
Maybe if you reboot in SAFE mode, could you get rid of the infected files?
