19 threads found!
Parkie | 8 | 289 | ||
Parkie | 8 | 246 | ||
Parkie | 12 | 347 | ||
Parkie | 16 | 380 | ||
Parkie | 9 | 389 | ||
Parkie | 4 | 209 | ||
Parkie | 12 | 350 | ||
Parkie | 10 | 291 | ||
Parkie | 6 | 295 | ||
Parkie | 5 | 288 | ||
Parkie | 2 | 117 | ||
Parkie | 5 | 248 | ||
Parkie | 13 | 110 | ||
Parkie | 7 | 121 | ||
Parkie | 3 | 58 |
102 comments found!
I got Carrara because it had a modeler or two built in. I mainly use the spline modeler. I like the ability to make trees. Being able to make other vegitation would be nice. Most of the interfaces are fine except for the metaball one. This I hate so I tend not to use it. Price is a concern but only because of our exchange rate.
Thread: falconperigot wins the contest! | Forum: Carrara
Thread: Glass shader and visible edges | Forum: Carrara
Thanks Markd, I've printed this thread to PDF so I can refer to it while I play. Cheers Neil
Thanks Mark I will try that. Your picture (top) is what I was expecting to see when I first rendered it. Markd, I have not purchased the fresnel shader plugin yet but thanks I'll have to have a play with that one day. Cheers Neil
Now that is worth a try. I only saw the candle holder for a quick glance in passing and thought that it looked interesting. I did a quick sketch on my palm but missed out details. While I initally thought the top was below the candles, I'll try it the way you have suggested and see. Thanks for the quick reply . Cheers
Thread: claudiomil Wins The Contest! | Forum: Carrara
Thread: Method to create "perfect" gears? | Forum: Carrara
There was a freeware program I got awhile back called gearmaker. You set all the gear parameters and it made an OBJ file. Works great for gears. I have just had a look and it is in the free section here at Renderosity Cheers Neil
Thread: * * * Vue Challenge for July is closed * * * | Forum: Vue
Thread: * * * Vue Challenge for June is CLOSED - Please vote * * * | Forum: Vue
Thread: Curiosity..... | Forum: Vue
Interesting see what is being used. My computer is as follows. Windows XP Home Computer: P4 3.0 with 1 gig ram Total HD 230gig across three drives Duel monitors: 19" monitor and 17" second monitor Video Nvidia FX5700 Colour 32bit 1280x960 one main monitor DVD burner Wacom Tablet Graphics Apps: Paint shop Pro 6 Vue d'Esprit 4.2 Carrara 3 Poser 4 daz Studio Project Dogwaffle Particle Illusion SE Canvas 7
Thread: The Hunted | Forum: Carrara
Thanks Steama & Sailor_Ed. Shonner: The haze effect worked well and was created using two volumetric clouds. Mateo_Sancarlos: Thanks. Yes that texture is stretched a bit but I had a hell of a time getting the texture to sit right. I had several images that had bad pixalation and that took me a couple of go's to work out. Nomuse: Thanks. The ground is similair to Vue that I use also. The texture came from a texture pack that nvidia put out a year or so ago and is just some mossy rocks. It does look good though. I guess it is what you get used to as I could never get the hang of Bryce. I like the trees also but finding textures for them took awhile. Cheers Neil
Thread: * * * May Challenge - the winner is.... * * * | Forum: Vue
Thread: * * * May challenge is closed ! Please vote * * * | Forum: Vue
Thread: * * * Vue Challenge for April is CLOSED - Please vote * * * | Forum: Vue
Thread: What are the 5 things you like most about Carrara ? | Forum: Carrara
