12 threads found!
PowerJet | 10 | 304 | ||
PowerJet | 4 | 5491 | ||
PowerJet | 4 | 2519 | ||
PowerJet | 1 | 3317 | ||
PowerJet | 3 | 2955 | ||
PowerJet | 10 | 717 | ||
PowerJet | 23 | 327 | ||
PowerJet | 3 | 241 | ||
PowerJet | 5 | 405 | ||
PowerJet | 3 | 654 | ||
PowerJet | 2 | 142 | ||
PowerJet | 4 | 216 |
10 comments found!
Thread: Scroll Problem! | Forum: Photoshop
Hi Paul.
Thanks for the reply, actually this is what I end up doing as I was unable to find any other way to disable the autoscroll.
Actually I have to zoom in the image real close and work on different areas,so if I make the image same as screen size still I have to zoom in to certain areas and will end up in same situation,I am surprised that I don't see any way to disable autoscroll any where in preferences.
Thread: HDRI How to Scale Down? | Forum: Vue
Thread: Decal Mapping in Vue Help required! | Forum: Vue
**Chip,Artpearl, nruddock,silverblade33 and Rutra
Thankyou sooooo much you guys specially Chip and Artpearl,this explains a lot and my issue is resolved,Chip thanks for the stuff that you have provided!
This is indeed a great forum to visit and getting help!
I am using Vue 6 and forgot to mention this is not UV Mapped in UV Mapper Pro or anything,I just want to display text as a Decal on this part which has metallic paint shader applied to it.
Thanks.
Thread: Looking For This HDRI Image! | Forum: Vue
Thread: Using Maps in diffuse and specular color channels??? | Forum: Vue
Thanks a lot guyz for your time,just to make things clear I have one more question:
Texture No.1
I am going to paint a basic color texture that will have color,markings,text on it .
Texture No.2
and a bump map which will have panel lines and rivets on it.
Now can you tell me to get a good looking metal feeling which texture should go in which slot?plus do I need to invert or not?
I know metal shader plays an important role but right now I am more interested in learning to get max out put by placing the textures in different slots.
Thanks a lot for your time.Once I will understand this I will put textures as per your advise in different slots and start playing with the settings.
Thread: Car Metallic Paint | Forum: Vue
Thankyou for the help,I have downloaded the files and will play with them.However the file for reflection object or the box which is required to display over the car is not working.Do you guyz have that?
Thanks.
Thread: Bryce 7 Pro Question? | Forum: Bryce
