3 threads found!
Razorcut | 7 | 2512 | ||
Razorcut | 17 | 251 | ||
Razorcut | 13 | 104 |
5 comments found!
Thanks for the info Orio! I did disable Open GL and it worked fine.
Message edited on: 10/07/2004 16:45
Thread: VUE5 MetaBlobs , anyone try these yet? | Forum: Vue
I figured it out. I have to select all the objects
at the same time before clicking on the Metablob button.
They cannot be made into Metablobs one at a time.
And you do not need to group or Boolean them fist. Just have all the objects selected at one time. To add more you have to reselect all the objects with the ones you add and push the Metablob button once again.
PS just tried using 4 spheres and crashed Vue within a few seconds trying to scale just one of the spheres.
I quess 4.2 Ghz with 512 Ram and a Pro graphic card is not quite good enough:)
Message edited on: 10/07/2004 15:36
Thread: Old purchased plants into Vue 5: how? | Forum: Vue
I had purchased plants for Vue 4 and they refused to work in Vue5. They asked for the serial numbers but it still did not work. I opened 4 and saved the plant as an object and then placed it in the vue5 object folder. Can import as an object now.
Thread: What is a good Digital Camera? | Forum: Photography
Thanks Magick Michael. I have used a couple of cameras here at work and noticed that some do not take good pictures up close. and some do not take good pictures from a distance. I really want to take still pictures up close. 1 inch or so but still get good quality at further distances.
Thanks.I have spent many hours reading different sites that rank cameras. Problem is there are just sooo many. By the time I am done reading about them all, there does not seem to be one that is best. Maybe there just isn't a perfect one:)
