2 threads found!
ReX | 15 | 280 | ||
ReX | 9 | 305 |
19 comments found!
Thread: BCE | Forum: Photoshop
Thread: Scanners | Forum: Photoshop
A Canon scanner I would definetly suggest. I bought a Canon LIDE20 recently and it does the job nicely. Oh and Cinema1954 Microtech doesn't make consumer scanners anymore
Thread: Tutorial | Forum: Photoshop
Thread: CMYK and green.... | Forum: Photoshop
if you're in RGB mode than turn on the Gamut warning (under the view menu). Anything that turns up gray is out of the CMYK gamut and won't look the same when you print it out.
Thread: help me with the color setting | Forum: Photoshop
Thread: 'Pencil' mode? | Forum: Photoshop
Thread: error when saving? | Forum: Photoshop
Thread: Pulling an object out of an image... | Forum: Photoshop
Thread: im desperate! prints | Forum: Photoshop
oops just re-read your problem... is the back 'stepping' into the other color on the print? What I mean is it braking up into sections of shades? This is called banding
Check the total ink % in the info box. If the black is lower than 260% (if your going sheet fed) then use curves to boost it up. If it's between 260% and 280% then your print will be fine. And Check the yellow level in the black mix. if it's too high then the black will look dull. if they are all fine then the dullness is a limitation of the proof printer Extra note: make sure you don't embed a profile. it's better to leave it untagged (saved w/o a profile) since you have no clue what the printer might convert the colour to.
