94 threads found!
TMGraphics | 10 | 240 | ||
TMGraphics | 1 | 85 | ||
TMGraphics | 3 | 89 | ||
TMGraphics | 18 | 249 | ||
TMGraphics | 6 | 41 | ||
TMGraphics | 8 | 59 | ||
TMGraphics | 6 | 60 | ||
TMGraphics | 5 | 44 | ||
TMGraphics | 6 | 72 | ||
TMGraphics | 8 | 100 | ||
TMGraphics | 19 | 130 | ||
TMGraphics | 5 | 47 | ||
TMGraphics | 3 | 39 | ||
TMGraphics | 7 | 58 | ||
TMGraphics | 5 | 40 |
992 comments found!
These may be of interest concerning refractive levels...
Air (STP).................... 1.00029<br></br> Acetone ..................... 1.36<br></br> Alcohol ..................... 1.329<br></br> Amorphous Selenium .......... 2.92<br></br> Calspar1 .................... 1.66<br></br> Calspar2 .................... 1.486<br></br> Carbon Disulfide ............ 1.63<br></br> Chromium Oxide .............. 2.705<br></br> Copper Oxide ................ 2.705<br></br> Crown Glass ................. 1.52<br></br> Crystal ..................... 2.00<br></br> Diamond ..................... 2.417<br></br> Emerald ..................... 1.57<br></br> Ethyl Alcohol ............... 1.36<br></br> Flourite .................... 1.434<br></br> Fused Quartz ................ 1.46<br></br> Heaviest Flint Glass ........ 1.89<br></br> Heavy Flint Glass ........... 1.65<br></br> Glass ....................... 1.5<br></br> Ice ......................... 1.309<br></br> Iodine Crystal .............. 3.34<br></br> Lapis Lazuli ................ 1.61<br></br> Light Flint Glass ........... 1.575<br></br> Liquid Carbon Dioxide ....... 1.20<br></br> Polystyrene ................. 1.55<br></br> Quartz 1 .................... 1.644<br></br> Quartz 2 .................... 1.553<br></br> Ruby ........................ 1.77<br></br> Sapphire .................... 1.77<br></br> Sodium Chloride (Salt) 1 .... 1.544<br></br> Sodium Chloride (Salt) 2 .... 1.644<br></br> Sugar Solution (30%) ........ 1.38<br></br> Sugar Solution (80%) ........ 1.49<br></br> Topaz ....................... 1.61<br></br> Water (20 C) ................ 1.333<br></br> Zinc Crown Glass ............ 1.517<br></br><br></br><br></br>Cheers,<br></br>Thomas
Thread: Hit a wall | Forum: Photography
Use household lights, clamp on lights, to mimic your 3d environmental lighting. Use something in front of a light to diffuse (make light not so strong as bare bulb) like a sheet, or pillow case for stronger effect. Use white cards (like posterboard) to 'bounce' light and reduce shadows.
Making the transition from 3d to photography is a matter of imagination (real world style).
Maybe you could post an image of what you are trying to accomplish and some images of where you are at with it.
Thomas
Thread: coffee filters | Forum: Photography
You can also use coffee filters to set your white balance. Two (bleached) filters together work best and give pretty close to 18% gray results. To set WB try the following;
1>Put lens in manual focus so that it does not hunt for a focus.
2>Hold the filters over the end of the lens and point towards light source(s) but never directly at the sun.
3>Use the image as your WB image and set camera to custom WB (This differs from brand to brand of camera - refer to your cameras manual on this part)
4>Put lens back into AF mode! Take pictures!
5>When you change scenes or the light changes be sure to take another WB shot!
6>When done be sure to set your WB back to Auto or whatever you normally have it set to!
I have, in a pinch, used a white dinner napkin at a wedding to set WB in a horribly lit room. Worked wonderful!
Regards,
Thomas
Thread: Professional SELECTIVE COLORING Tip To All Rosity Photographers | Forum: Photography
Thread: Was wondering ..... | Forum: Photography
Thread: The very, very basics of Bryce 5.5... | Forum: Bryce
Thread: OT Free USB Hard Drive Rant | Forum: Bryce
Thread: Glare on Glasses | Forum: Photography
Thread: sun light cant see :-( | Forum: Photography
Thread: Palmetto tree | Forum: Photography
Thread: How to create glass material, any tuts out there? | Forum: Poser - OFFICIAL
