1 threads found!
TeddyBe | 8 | 132 |
2 comments found!
It isn't. You can only work with one Poser at the same time!!! In fact, you can't use 2 poser versions with the same serial on a network at once!!! Copy from EULA of Curious Labs: Can I install Poser on more than one computer at a time? Yes. Your Poser 5 End User License Agreement (EULA) specifically allows you to install your copy of Poser 5 on more than one computer provided you never run that copy on more than one computer at a time. For example if you have a desktop and a laptop computer, you may install Poser 5 on both computers but cannot run the application on both computers simultaneously. You will need to register on both systems as they will create unique Challenge and Response codes for each system. Can I run the same copy of Poser 5 on more than one computer at a time? No. Running your copy of Poser 5 on multiple machines is a violation of the Poser 5 license agreement. Poser automatically checks your local network (if any) for other running versions using the same serial number. So, I don't violate the EULA, since I only run Poser on one System, the others just needs Poser to be installed, so my networkrendering works. In case you don't agree with me, tell me why Poser is telling me that I can't run it twice on different systems on my network, but doesn't tell me anything at all while it acess it with the networkrendering? greetz, Steven.
Thread: Network Rendering with poser5, Bodystudio & Max5.1 | Forum: Poser - OFFICIAL
Attached Link: http://trailer.digitalmedia.be
First of all thanX for all the reply's!! Just Install Poser5, then SR4. While starting Poser5SR4 for the first time, enter the same serial as your 'working system'. That's it. I've solved the problem by copying the runtim folder to every single system on my 'renderfarm'. Now everything works great!!! IMPORTANT: You have to keep all the files in sync on every system. I've found a great program to do it automatically. It's called 'File Syncforce' and you can get it from http://www.objectforce.com It works fine and on every change in the runtime-folder on my working system, the program updates all the systems in my 'farm'... greetz, Steven PS: Check our trailer, made on Max with the help of Poser5, mimic and bodystudio. http://trailer.digitalmedia.beThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
