2 threads found!
Posted Aug 17, 2003 at 5:30 am | Forum: Poser - OFFICIAL |
Weezle | 6 | 195 | |
Posted Jul 12, 2003 at 9:39 am | Forum: Poser - OFFICIAL |
Weezle | 10 | 267 |
4 comments found!
Thanks, I actually tried also that before writing my post. With some boots i have used this "body-part-off-thing" and it worked ok. I have also tried to apply first clothes and then do posing. If i use this French Maid set that way, Pettycoat acts same way as Maids Dress. But if i do it like i told before i get atleast Pettycoat work ok. Its true that lot can be fixed at postwork but for example again this French Maid set. If i start from zero pose, add pantyhose, conform it and then load this My Feet Hurt-pose i have holes in pantyhose ("poke-through"). Cant fix that with hiding body parts and it is not so fun to fix it at postwork. But if i got this right, there is no way to do this anywhere else than for example fix it with photoshop etc. ?-)
Thread: Clothes and Poser | Forum: Poser - OFFICIAL
Aaah, that was the problem. Seems to work ok now. I didnt realize that there is difference between using import obj and using library. Thanks!
Hmmh.. Ok... Well, i tried that table thing and it worked fine. But now i am playing again with my V3 and Fantasy/Belly Dancer set. Still cant understand how to do it. I load V3, I load dancer loincloth. It seems to fit ok to char. Now, do i have to do something special before going to cloth room? If i turn V3 upside down, cloth wont move with V3. Soo.... How do i attach my cloth to char? And how on earth i can make it fall down? Or, do i need to import this cloth and not to use this.. thing on right side to load it?
So, if I understood right, there is no way to do this with cloth which you can conform to character? If i don't conform it, should i use parenting instead?
Thread: Still confused with Clothes and all | Forum: Poser - OFFICIAL
