5 threads found!
alfhak712 | 2 | 54 | ||
alfhak712 | 4 | 111 | ||
alfhak712 | 0 | 53 |
(none)
alfhak712 | 10 | 272 | ||
alfhak712 | 13 | 209 |
7 comments found!
Thread: How do I know if Poser cloths, props, scenery works for DAZ? | Forum: DAZ|Studio
Thanks for all comments and reply!
I bought one car some time ago that say only Poser but thought it was going to work
for DAZ! I could install it but could not edit or change things on the car!
I think the best thing would be to sitemail the vendor for products and ask if it does not
say it works for DAZ!
Alf
Thread: Having Issue with animation with some crash and error report! | Forum: DAZ|Studio
Thank you Hiro!
I did a small mistake doing the animation! Both cars coming from the left driving to the right, stop at the same time but have different start position! If you look careful you will see the second car closing in to the car in front! I should have make the stop position furhter away for the first car! This is the first animation that I manage to get the lightning ok and also have a distance light acting as sun! So some nice shadows on the street and even from the passing cars!
Alf
Thanks for all good advice and tips!
Today I got reply from DAZ about my Error Report! I need to uninstall DAZ and get the newest version first and also try to get more RAM. Also a note of that I will run out of memory on 32 bit version when trying to render large/complex scenes. So a 64 bit version only and latest version of DAZ.
Render to images sounds like a better idea and now I think I got an idea how to put them together into a movie with Corel Studio Pro I use! I got some tip about how to do it and then some trying and error until I got it to work with not spending to much time!
I found a way to select all images and then copy them to clip board. After install all images in a sequence from my folder I could hightlight all of them in Corel by holding down CTRL+ALT key and then mouse click there the images was placed! Then all selected drag them down to clip board!
Also on clip board I select the first high-lighted the first image then press shift key down and then select the last images for the movie! That they all get selected and then I could edit the time for each frame to be shown! So all 150 images was edited at the same time! This way I did not know was possible to do but it save lots of time instead of working with one frame at the time! The movie is just 5 seconds long and it end up almost the same in Corel and also looks ok!
Here is the movie!
http://www.youtube.com/watch?v=kmraCHElEoQ
Alf
I running both version of DAZ, 32 bit for animation and 64 bit for images!
The reason for this is I can't get the codec for animation to work with 64 bit version! Even if I have download extra codec that should work!
Alf
Thanks for your reply!
I am using disks running at 10 000 RPM and I guess it is possible
to have 12GB of RAM too!
Alf
Thanks!
I checked the page and it also say you need lots of memory! 16GB
I only have 6Gb atm! Does that cause any issue?
Win 7 64 bit OS
Intel Core i7 CPU 920 2.67GHZ
Alf
Thread: Which version of Lux render should I use for Reality 2 for DAZ Studio 4.6 64bit! | Forum: DAZ|Studio
