25 threads found!
attilako | 7 | 107 | ||
attilako | 4 | 131 | ||
attilako | 8 | 307 | ||
attilako | 6 | 169 | ||
attilako | 3 | 125 | ||
attilako | 9 | 143 | ||
attilako | 4 | 158 | ||
attilako | 3 | 88 | ||
attilako | 7 | 145 | ||
attilako | 15 | 266 | ||
attilako | 17 | 662 | ||
attilako | 1 | 2064 | ||
attilako | 1 | 50 | ||
attilako | 3 | 89 |
49 comments found!
Thread: Image disappear after opening the Material Room. | Forum: Poser - OFFICIAL
It;s in the Poser room window. But I cannot use one sided polis, because my camera goes around it. And high polis are no good for a whole forest.
Poser 7
The flat is a two sided polygon, it's just a background picture. An image or texture is laid on it.
Thread: Facial animation. Kinect to Poser characters | Forum: Poser - OFFICIAL
I was thinking just to import a BVH file and assign the bones to the corresponding face morph for a special poser figure. But it seems, life is not so easy. .....ok we keep the talk designer
thanks for replying
Attila
Yes I could use the talk designer and that's what I'll do if there is no apps for
face mocap. I've heard about Faceshift for MAC but they take 800$ every year
Thread: M.O.M Forest Generator | Forum: Poser - OFFICIAL
I got it now! I'm sorry that I didn't notice there were two files in my basket.
Thank you
Of course I own the Crowd Generator. I bought it from Renderosity two years ago.
I havn't contacted the vendor (Powerage) yet
Thread: Not able to freely move props in figure | Forum: Poser - OFFICIAL
I can only move them with the parameter dilals. If I do it with the mouse the objects(bodyparts) are rotating around the center, and I can't move the freely
Thanks for the ideas, I can now move them with the mouse,
but not with the 3D mouse (3D Connection) ... and unfortunately I use the 3D mouse 95% of the time.
Thread: How to make doublesided materials? | Forum: Poser - OFFICIAL
It's interesting that Poser preview mode can actually show both sides of a simple square wich you load from the props. And it is so thin that you cannot see thickness or two plates close together. How did they make it?
Why can't we use the same system for a skirt? or a house wall?
Thread: Cartoon display style goes wrong. | Forum: Poser - OFFICIAL
"Set document style to texture shaded and Select the figure you want in cartoon style and go into the Display menu of Poser and set figure style to cartoon."
.....that's exactly what I did, but the result is picture number two (above)
Thread: Master dial to control several dials in the material window. | Forum: Poser Python Scripting
This little script "Markschum" gave to me works OK with figures with body parts in it.
But I have another kind of figure which looks like this
http://atko.dk/langw/forums/Picturetrees.png
Would that be possible to modify this script to work with non body part figures? Instead body parts there are just objects (trees).
Thanks
I tried the script, but unfortunately it doesn't change the diffuse value. The python window
has only one word in it and that's the figure name.
I copied this script to a blank text document with .py extention and placed it to poser pythons scripts.
But when I opened it in Poser, the python window was blank.
Thread: Background image is unsharp | Forum: Poser - OFFICIAL
Thank you so much for your ideas, that made a huge difference!
Now it's clean sharp. Both the cam settings and the texture filtering.
Now I use "none" on the texture filtering
Thanks again
