13 threads found!
chrisdoa | 19 | 341 | ||
chrisdoa | 6 | 193 | ||
chrisdoa | 0 | 55 |
(none)
chrisdoa | 6 | 153 | ||
chrisdoa | 2 | 97 | ||
chrisdoa | 2 | 13 | ||
chrisdoa | 15 | 79 | ||
chrisdoa | 8 | 111 | ||
chrisdoa | 6 | 96 | ||
chrisdoa | 4 | 96 | ||
chrisdoa | 8 | 70 | ||
chrisdoa | 18 | 337 |
26 comments found!
Thread: Why is m4 blue? | Forum: Poser - OFFICIAL
Thanks, that the solution. I've never really noticed in V4, but it drove me mad in M4. Can you tell me if there's an easy way to adjust the diffuse colour to all the map at one go, as I've had to do each part seperately.
But look at my picture, the conditions are the same but my M4 is distinctly bluish and M3 renders normally, like yours.
Thread: M4 rendering blue | Forum: Poser - OFFICIAL
Well you got it completely right. Turned off the GC and all is well, but the price paid is the renders now seem over bright! I'll have to start tweeking when I feel braver. Now I can use M4 having paid for him!
Thanks!
I looked into the material room and your on the right track. All the surface textures have a light blue diffuse colour, that if I alter solves the problem. Only thing is that I don't know how to change for all the texture with out doing each invididual part. Surely I an't be the only one with this or is there a setting wrong in my copy?
Thread: Slow animation | Forum: Carrara
Ok. Thanks for that. Its reassuring to know I'm not doing anyting stupid and just need to be a bit more patient.
Cheers Chris
Thread: How do you import poser into c4d? | Forum: Poser - OFFICIAL
Thread: poser rendering | Forum: Vue
Thread: which is the best rendering engine for dual core? | Forum: Poser - OFFICIAL
absolutely no idea. I liked the idea of dong something else whilst p6 got on with rendering, but if the whole process could be speeded up I'd love that. Vue does sound like good option. Does it support nettwork rendering as I've got an Athlon 64 3500 sitting around with spare MB and drives?
Thread: Poser and cooling: a question | Forum: Poser - OFFICIAL
Just had a very bad experiance trying to fit water cooling. First broke motherboard trying to remove fan housing Duh!! Then when I fitted the fan radiators they leaked, spraying water all over the new board. After 2 days drying and new radiators I tried again. No leaks buit the board was damaged and it also blew my graphics card, an X800 pro. Not to happy at the moment, but atleast the machine is really quiet:)
Thread: Dynamic Hair collisions | Forum: Poser - OFFICIAL
Just bought genesis2, so I'm going to have play with that. I also tried Gensis for V3. Its the reason I'm persevering with dynamic hair as it gives a much better look than i previously seen from this type of hair.Before your work I been a bit unconvinced, but I now seen the results when its well set up, Cheers Chris
Thanks for that. It seems to really slow things down tho'infact it seems to freeze my machine. I have P6 on anAMD64 3500 and 2 gig.Am I doing anything wrong do you think?
