1 threads found!
Posted Aug 17, 2012 at 6:02 pm | Forum: Poser - OFFICIAL |
colpolstudios | 8 | 229 |
6 comments found!
Thread: Helping Poser Newbies | Forum: Poser - OFFICIAL
I am hoping you will help me with a newbee question.
I wish to use my normal map within poser but I can not find a normal map within the material room.
I placed my normal map image into the bump section but is this correct?
Would you recommend that i use a bump map image ?
Thread: my first model and need help understanding seting up the Hierarchy | Forum: Poser - OFFICIAL
Hi, it turns out my model was incorrect and i am getting help to solve the isssues.
many thanks for your kind help
Issue closed
Hi after a little reasearch i have found the error, the point of orgin upon import of the model was changed.
How do i change the point of orgin inside poser 8 ?
@ samTherapy when tried to simply load the separt pieces into poser i get these issues.
Give me a little time an I will post a screenshot of poser ok ?
brief description of issues.
the outer plints end up inside the outer ring main.
It is like everything is loaded on top of each other, but the main concern is the inner ring as it loads in the wrong location.
possibly I need to save the .obj files and export them with daz export, with poser units selected for correct scale.
