1 threads found!
cr2012 | 7 | 179 |
5 comments found!
Thread: Point at function severe bugs and not working as it should. | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Dear PhilC thank you very much for your help I think I figured out what you mean Andy is now moving his head up and down according to the position of the camera.
Strange that none of the tutorials out there mention anything about having to adjust the joints the tutorials you find on the internet they talk like the point at feature works without problems from the start which is not the case in my Poser Pro 11.
Dear PhilC thank you so much for your quick reply.
I aligned the green and the red making the center point and end point the same but the problem now is when I move the camera the point at function seems to do nothing there is no head movement when I move the camera any ideas?
Thread: Superfly and Skin - adapted Cycles shader | Forum: Poser - OFFICIAL
WandW posted at 1:41AM Tue, 02 February 2016 - #4252589
Ask him over at RDNA, as you are more likely to get an answer there...
http://forum.runtimedna.com/showthread.php?102517-Skin-shader-from-Blender-thread-WIP
Ok thank you WandW :)
This is the progress I have made so far with researching and experimenting since I asked the question earlier.
bagginsbill posted at 11:23PM Mon, 01 February 2016 - #4248118
ghonma posted at 1:27PM Sat, 09 January 2016 - #4241565
Definitely better. I would also suggest not using Poser figures/textures to tune your shader. Instead get something like the free Emily and use that:
http://gl.ict.usc.edu/Research/DigitalEmily/
That will help reduce/eliminate any effect low quality poser textures and mesh may be having on your results. Later you can fine tune for poser content.
Hey thanks for the link. I didn't know about this download. Rendered in SuperFly, but using a simple FireFly shader having only color map, bump map, Scatter node, and Blinn node. You guys are overcomplicating things, IMO.
It looks very good Bagginsbill can you please upload a .mt5 file or can you post screenshots on how to setup the shaders in the material room? I really want to learn to make superfly shaders for human skin.
