81 threads found!
craftycurate | 2 | 283 | ||
craftycurate | 5 | 312 | ||
craftycurate | 2 | 147 | ||
craftycurate | 10 | 975 | ||
craftycurate | 4 | 170 | ||
craftycurate | 7 | 1083 | ||
craftycurate | 2 | 386 | ||
craftycurate | 4 | 1491 | ||
craftycurate | 5 | 848 | ||
craftycurate | 12 | 1327 | ||
craftycurate | 10 | 431 | ||
craftycurate | 7 | 552 | ||
craftycurate | 2 | 1355 | ||
craftycurate | 4 | 418 | ||
craftycurate | 3 | 278 |
282 comments found!
Thanks for your help ... however, it doesn't seem to work for me.
If I load the saved VOB (area light sphere) as an Ecosystem object and then convert to a particle, the objects glow but do not emit light in the scene (see plane on the left in image below).
If I simply load the VOB into the scene as a single object, it does emit light (right hand side of the image).
See the example below. The sphere in the centre is an area light sphere, saved as VOB and loaded using Load Object. The plane in the left corner uses the same object as an Ecosystem object converted to a particle. All the light in the scene is coming from the sphere in the middle.
Maybe I missed something?
Cheers
RichardÂ
Thread: Did Interactive Material Placement make it into Vue 10 Complete? | Forum: Vue
Cool ... I couldn't find it in the feature comparison table, but then it is pretty long!
Are you a Complete user or did this info come from a page I could look at?
Cheers
RichardÂ
Thread: What was new in Vue 8 Complete? I missed a version ... | Forum: Vue
Thread: Left without an upgrade path ... | Forum: Vue
I won't give details but E-on has responded in the way I'd hoped and made me a good offer, which I've accepted.
Just so you know - it is worth asking and they do value long-time customers!
Thread: XFrog 4.2 for C4D for free | Forum: Vue
Thread: Up To Date C7.2 Pro Help PDF? | Forum: Carrara
Thanks - I couldn't find it at DAZ or on Google. Funnily enough, this version shipped with the C7 Pro demo, but not the release version.
Thanks
Richard
Thread: What do you think is happening here? | Forum: Vue
That sounds right - the UV map has to be deformed too. I felt it was something to do with UV mapping, but it's something I am only just learning.
Thanks
Richard
 Yes, I've tried that, as well as "Automatic" and "Flat".Â
UPDATE: This also happens with a built in Vue object (table + tablecloth).
Thread: Apply Quadratic Light Attentuation to Luminosity? | Forum: Vue
Thread: Sort of OT: 100 FREE XFrog models | Forum: Vue
Thanks for heads and up thanks Bruno for the tips. Have also found LWO the best.
Cheers
Richard
Thread: Can Collada Models be Posed in Vue 8? | Forum: Vue
Woohoo - works a treat. Collada models exported from DS can be easily posed in Vue 8 PLE.
Thanks
Richard
Thread: Looking for Poser 7 Install Disk (NOT Serial - I have one) | Forum: Poser - OFFICIAL
Hi John ...
I sent a note for your attention on SmithMicro support, but one of your colleagues answered it with the standard information.
When you said "Let me know your Order Number or send me a Scan of your Box Front, and the front page of the Manual if you purchased it other than Smith Micro (e frontier, CP, or Smith Micro) and I will see what options are available." ... does this mean there might be some possibility of obtaining the old installation files?
Thanks again
Richard
Thread: How to Create Lights as Particles e.g. Sparks? | Forum: Vue
