4 threads found!
cristihp | 10 | 173 | ||
cristihp | 3 | 96 | ||
cristihp | 8 | 228 | ||
cristihp | 2 | 67 |
4 comments found!
maclean, what's the meaning of those "0 0" after the lines with texture calls? Indeed, I have "0 0" only after reflection maps calls, but not after texture or bumps calls... And the only ones that load are the reflection maps!!!! I don't use any strange paths, and as a tip, you can also use something like ":foldername:texturename.jpg" instead of a "runtime:textures:foldername:texturename.jpg". It works. anyway, what's the meaning?
Thread: Why don't the textures load? why only reflection maps are loading? | Forum: Poser - OFFICIAL
The file is in zip format, after extracting, everything lands in the correct location. The textures are jpg's the reflections are also jpg's and the bump map is a .bum. The figure is a cr2.
Thread: Motorcycle figure problem | Forum: Poser - OFFICIAL
Yeap...Indeed, the Bending was checked. Now it works perfectly... Thanks alot guys, and as soon as the motorcycle will be available for sale, you two will get this moto as a gift. Offcourse, if you want to... :)
Thread: Conforming brain smashing problem (going crazy) | Forum: Poser - OFFICIAL
The shirt is imported correctly in Poser, the problem always seems to appear when I conform the shirt on Victoria. The shoulders of the shirt go inside Victoria's shoulders <:( Yes, I've zeroed the Victoria figure before exporting it, set all the morph dials to zero, and so on. I've downloaded today Sexy Leotard for (Vicky) from the free stuff page and I have the same problem.Now entire areas of the leotard go inside Victoria. What's the problem? I've also tried to use someone elses cr2 and redirect the obj. But I get the same results.
