18 threads found!
drackliffe | 13 | 206 | ||
drackliffe | 4 | 95 | ||
drackliffe | 5 | 175 | ||
drackliffe | 2 | 89 | ||
drackliffe | 3 | 90 | ||
drackliffe | 2 | 83 | ||
drackliffe | 27 | 604 | ||
drackliffe | 5 | 33 | ||
drackliffe | 4 | 94 | ||
drackliffe | 4 | 149 | ||
drackliffe | 22 | 512 | ||
drackliffe | 2 | 57 | ||
drackliffe | 4 | 132 | ||
drackliffe | 7 | 148 | ||
drackliffe | 12 | 333 |
23 comments found!
Thread: Trying to make a light bulb man | Forum: Poser - OFFICIAL
Â
http://www.fotosearch.com/SUE116/slbw0192/
Â
something similar to this. Hope it came thru. Just a real basic light bulb.
Oh, that's a good idea. I'll give it a try.
Any suggestions on a good light bulb prop?
Â
Thread: Poser 7 Display Refresh very slow | Forum: Poser - OFFICIAL
Thanks for all the advise. Looks like changing to SreeD did it. I will probably be upgrading the Video card soon too.
Thanks again for all the help. Happy Posing
Thread: Rotating all lights together | Forum: Poser - OFFICIAL
Thread: Morph Transfer...:O | Forum: Poser - OFFICIAL
[http://www.evilinnocence.com/xd/
](http://www.evilinnocence.com/xd/)I highly recommend CrossDresser. I works great You only need to pay for the target figure.
Thread: P6 Lighting too bright? | Forum: Poser - OFFICIAL
Thread: Is it possible to replace the default figure on load up? | Forum: Poser - OFFICIAL
Yes it's very easy. Set up the Pose area they way you want it. ie figure, lighting, display settings, etc. Then go to Edit, preferences and click on set prefered state. Then select load to prefered state. The exact terms may be a little off, I'm going from memory but that should give you the gist of it.
Thread: P6 saving to library problem | Forum: Poser - OFFICIAL
Thank you for the advise. I'll try it when I get home tonight. Hopefully they fix this with the patch.......
Thread: P6 problem issues and fixes | Forum: Poser - OFFICIAL
Thread: "Clothifying" breasts in P5? | Forum: Poser - OFFICIAL
Thread: Over sized dynamic cloth??? | Forum: Poser - OFFICIAL
I just figured out how to fix the problem. In the cloth room I went to edit constrained group... Then removed all. The ends of the sleeves were constrained and wouldn't drape when they were on.....
Thread: seams in skins | Forum: Poser - OFFICIAL
