Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 05 9:36 pm)
Hi, yes, this is exactly how I have my default lights set up. It provides an even illumination whilst I'm creating a figure. For each light:-
In the properties panel set the light type to Spotlight.
The "Set Parent" button will then become enabled and you can use it to parent the light to your camera.
Now set the light type back to Infinite (or whatever you require). The parenting will remain in effect.
Hope that helps.
Similar to Phil, I have my Default Scene saved with three Spotlights, all already Parented To, and set to Point-At, an invisible box prop. The lights are preset to a typical 3-point portrait setup with a Key, Fill, and a Backlight. Having them already set-up & Parented in your Default scene saves a ton of time.
By parenting them to a separate dummy prop (rather than directly to a camera or a figure) you can easily tweak them all together, but not have them jumping around every time you adjust your other scene objects.
And of course, you can still quickly parent this dummy Light Parent to another camera, Fig, or Prop temporarily, then, after adjusting the scene, un-parent it again, and keep them in place.
Is there a way to rotate all the lights in a scene together at the same time.
For example. I've moved my camera 180 degrees and now the lights are all wrong. I'd like to have the exact same lighting set up I head in respect to the camera from it's original position. Is the possible?
I hope I explained it clearly.
Thanks,
D
