3 threads found!
dwj012754 | 20 | 544 | ||
dwj012754 | 5 | 1213 | ||
dwj012754 | 1 | 14 |
7 comments found!
I did want to complete this post, just in case someone else searched and located it. I tried all the above suggestions, de-installed and re-installed numerous times. On my Windows 7 machine, I could never get it to not crash after adding basic child or basic female or basic male, even though the genesis character would install.
I always installed Poser 9, followed by SR3.1, followed by the DSON importer to the runtime directory. I tried installing the two Genesis packages to the runtime, into the default My Documents and other areas.
I then tried it on my home machine with Vista - same problem. Sigh...
I then tried it on my second work machine, Windows XP.
In all cases, I get crash to the desktop whenever I add in the basic characters, except for Genesis. When I add in things like hair or clothes, I get error messages, but the actual item does render in the screen.Â
AttributeError: SetGamma Traceback (most recent call last):  File "C:Usersdenjones.TURNERDocumentsGenesis EssentialsRuntimelibrariesCharacterDAZ HairAldoraAldora Hair.py", line 2, in    dson.dzdsonimporter.loadCompanionDSONFile( sys.argv[0] ); SystemError: NULL result without error in PyObject_Call
I can see files being created in the data directories for these items. However, adding in any of the basic characters crashes for all environments.
I will just have to wait and see if future versions of the DSON import might work.
Thread: Poser 9 crash after Genesis/DSON install | Forum: Poser - OFFICIAL
Thanks for the suggestions. I tried using the Security tab on the folder to make it accessible to all users. I tried setting the Writeable Runtime folder to the Poser9 Runtime. In all cases, the program still blows up after applying actor settings. I also tried setting it to my users/public/DAZ3D, but to no avail.
Thread: Problem installing vicky 4 on Windows 7 Error reading INI file | Forum: Poser - OFFICIAL
Thanks very much for the reply. I did create an empty file with the exact path and name and then the dialog popped up to allow me to browse to the new runtime location.
I had searched for the problem in the forums and you had several posts on the subject. This response was perfect for me. I appreciate the help.
Â
Thread: Real people imported into poser with new prop, sort of :) | Forum: Poser - OFFICIAL
It looks a lot like Jessica Biel from Seventh Heaven to me. You should give us some details on your prop.
Thread: New Poser related website | Forum: Poser - OFFICIAL
I took a look at your site. A bit of HTML overprint on the yellow text on your second page. The site is well done. You had a couple of download items that I pulled down. The gallery images were very artistic.
Thread: Nicole Gets a New Pool... | Forum: Poser - OFFICIAL
Very nice work. The pool set is one that will appeal to a lot of renderers. Nichole is gorgeous and we look forward to the resolution of that copyright issue.
Thread: 3 months to make only the FACE (new Victoria Character) | Forum: Poser - OFFICIAL
This is an exceptionally beautiful face. I can only imagine the challenge that awaits you in putting a body and shape to the character. This could be a wallet emptier.
