6 threads found!
februus | 1 | 3219 | ||
februus | 3 | 12 | ||
februus | 3 | 21 | ||
februus | 2 | 9 | ||
februus | 2 | 11 | ||
februus | 3 | 12 |
90 comments found!
The Genuine Fractal plug-in for Photoshop can do this better thatn anything-but it's expensive and for the Mac only I believe. Printer ready is generally 300dpi, lo rez 144dpi and web use 72dpi, but you can resample the image in Photoshop and still do OK. If your stickers (MacTac) are printing with a docucolor printer you are not going to lose much image quality between 150 and 72dpi. Just don't compress the 72dpi file (some artifacting comes from compression and re-saving) your files.
Thread: Mosca censored!!!! | Forum: Poser - OFFICIAL
Mosca-a Clear Policy: if the Fairy Felches it should be taboo. :) :) :) ANYBODY GOT A POSABLE SILLY STRAW?
Thread: Creepy Clown and Pro Pack Problem. | Forum: Poser - OFFICIAL
P.S. -been visiting these poser sites since they started up, but this thread pretty much immortalizes Poser as far as I'm concerned.
Man! Creepy the Clown Without Shoes-is about as sick as sick is! My nightmares are about chainsaw wielding SHOELESS clowns-and if ProPack can't handle it-shit! will the world keep spinning?
Thread: EYEBALL session | Forum: 3D Modeling
Thread: OK READ ME PLEASE | Forum: 3D Modeling
I'm available after 10pm Central-what should I wear? Max, LW, Rhino or Nendo? Yes, I said Nendo-that's what I started with in learning sub-division basics, and I still crank it up on Saturday mornings with a bowl of Lucky Charms in my mitt, the cartoons blasting...whatever the hell happened to Nendo?
Thread: My first post as a Mod, of the new OffTopic Forum!(The *what*?!?) ;] | Forum: Community Center
Hah Hah, Congratulations Micheleh-I knew you'd be a natural for a Mod! But the really funny thing is, they put possibly the most level-headed individual on the site in charge of the "Off Topic" forum. This should be great! Now, if they'd just turn the whole show over to you... Congrats, again! februus
Thread: Tutorials on MAT files now available | Forum: Poser - OFFICIAL
Thread: I have recently been to the Galleries and WOW!!!!! | Forum: Poser - OFFICIAL
Just click the upload option and fill in the fields-copies your jpegs to the server-oh,make a thumbnail version of your image file and include it in your upload.
Thread: Freebie updated... | Forum: Poser - OFFICIAL
Thread: Daz Ogre | Forum: Poser - OFFICIAL
Thread: Updated Freebie | Forum: Poser - OFFICIAL
Thread: Any pointers on this effect? | Forum: Photoshop
The basic work shown in the after image can be achieved using several simple techniques. The tools you must master are: the layering option, the fade command and your airbrush. Take your original poser render and add a layer, use your lasso tool to select areas you want to brighten on your figure (example: look at the legs-following post work there is a whitish light flowing down the curves of the legs) Lasso inside the leg top to bottom, using a white pigment set your airbrush to 30-50% strength and lightly spray into the selected area-be as uniform as possible and don't over fill the area. Now select filter/ fade from your taskbar commands and slowly decrease the white pigment you just airbrushed in. As it fades you will have the same effect as the one you see-just keep practising this. The best results are when you learn to carefully select areas to hilight and learn to fade properly-the fade filter/effect/tool command combined with layers is the single most effective series of photoshop tools at your disposal. Remember to combine your layers. Then as pneal suggested above: use the curves command and add points at the top of the curves line segment and at the bottom of the line segment and move them to add weight and body to your skin tones. That's pretty much all you need to get the look you're after.
Thread: 'Standing Tall' by Will Kramer | Forum: Poser - OFFICIAL
Hope Will has great success with his prints-he's a friendly chap with mucho talent. Very inspiring work-thanks for the notice!
Thread: June Challenge Entry - Things that go bump in the night | Forum: Bryce
Thread: 72 dpi..... | Forum: Photoshop
