We couldn't find any threads matching the specified search criteria.
4 comments found!
I purchased your product the other day for $34.95. I see it's priced at $31.45 now, I guess my bad luck.
I have versionĀ (V1.1.5.3) and all looks good so far, renders in P4, but not with firefly. The *Body.jpg is good and when I render with firefly " NO DECAL " is on my figure.... This is a wonderful product, but I need it to render with Poser 7 ( autosetings and manual tried ) both fail with fireFly! Looking at the promo I can not see P4 only..
fm
Thread: Lillith for V4 | Forum: MarketPlace Showcase
I rendered Lillth with your (Min shading rate of .2<) No seam lines. I was using a rate of 2.> As I said I am new at this. Will try to find out how "Min Shading" effects Firefly renders. Buy the way, is there informatiom on how each of the firefly render settings effect the output, or is this a hit and miss thing?
Thanks for your help!
fm
Thanks for your prompt reply. I am using Poser 7 . Latest updates applied. The lines show up on the final render. When I get home I will post to you the render settings I am using. A little different from your post. The difference that I am using is (Min shading rate = .27 or larger).
fm
I purchased the COMBO Lillith package. The work is great, but I am having a problem with the character mat ( I think, I am new at this) , I am getting seams on both legs and in the left arm area. I have removed the package and reinstalled. Still problem with seams. This is a white line on both legs at the stocking line. Is there some way to remove this?
fhoaglan@hotmail.com
Thread: DecalMaster in now available - edit your textures with drag&drop | Forum: MarketPlace Showcase
