3 threads found!
Posted May 06, 2002 at 1:29 pm | Forum: Poser - OFFICIAL |
genetic | 3 | 77 | |
Posted Mar 15, 2001 at 12:42 pm | Forum: Poser Technical |
genetic | 1 | 7 | |
Posted Mar 05, 2001 at 10:28 am | Forum: Poser - OFFICIAL |
genetic | 2 | 15 |
3 comments found!
Thread: Need help with winzip please....? | Forum: Poser Technical
Have you tried reinstalling WinZip? What version of Winzip are you using? It could be one of the those to problems. Also not all the times will there be folder names assigned to the files. There might be some text file that gives information on how to install everything. Next guess, is see if when you go to export, you have the "use folder names" box checked.
Thread: Poser 4 to Max 3.1 | Forum: Poser Technical
Actually i've encountered problems with the export tool in Poser 4. I've found that if you export them using alot of Poser's objects and morphs as a 3DS file, 3D Studio will read it as an improper file format. For some reason,however, i can export a figure in a pose really good but if they aren't wearing any clothes. The only solutions I have found is one that might not be right for you. But if you have true space, there is a plug-in you can purchase at http://www.gothicsystems.bizland.com/news.html. The name of the plug-in is object man. It will import several different file formats (including quake files) and export them in to many other ones including 3DS. I've been able to export the files as an alias object file and resave it as a 3DS file that works for 3D Studio Max. Unfortunatley you can't export the animation in a sequence that is saved into the file. But at least you can get the model in there.
Thread: Poser pose window all fudged up | Forum: Poser - OFFICIAL
