7 threads found!
ghostman | 6 | 350 | ||
ghostman | 2 | 104 | ||
ghostman | 1 | 98 | ||
ghostman | 2 | 98 | ||
ghostman | 7 | 226 | ||
ghostman | 11 | 288 | ||
ghostman | 2 | 105 |
772 comments found!
So far from what I know only GoZ to zbrush will manage that.
"Dream like you'll live forever. Live like you'll die tomorrow."
Thread: La femme Sneek Peak | Forum: La Femme 2
Thread: Help needed | Forum: Poser - OFFICIAL
Once upon a time in a poser program far far away it converted rsr files to png every time that item was loaded in the library
Thread: Japanese Soldier WW2 | Forum: Poser - OFFICIAL
there is one over at Poserworld
Thread: What Poser actually can do... | Forum: Poser - OFFICIAL
Well i've seen enough of yr posts through the years and I have never seen you post anything positive unless it is bashing other peoples work when they are trying to make figures. I'm amazed that with yr "so called knowledge" In figure creation you would have made a figure that filled everyones needs by now,
Thread: Poser 13.0.339 Pose Symmetry doesn't seem to work properly... | Forum: Poser 13
3D-Path tool is not a thing anymore in poser. It got ditched.
This is something that have been adressed in the beta and will be fixed in the next update.
Thread: Does Poser 13 have micropoly displacement? | Forum: Poser 13
If you use Firefly render engine yes. Not in Superfly. Superfly does only have normal Displacement.
Thread: Finally got LaFemme2.0, and I am liking what I have | Forum: Poser - OFFICIAL
@rokket Looking real good though. Cool outfit.
That is just LF1
Thread: The Poser 11 content install | Forum: Poser - OFFICIAL
Maybe this is what you are looking for. I've used it alot and it is alot easier than using the setup room.
https://www.renderosity.com/rr/mod/bcs/hierarchy-builder/87368
Thread: Need a good rigging tutorial | Forum: Poser - OFFICIAL
Nice work rokket. :)
Thread: Visible seams with EZSkin P12 | Forum: Poser 12
I'm pretty sure that the Collada and FBX import/Export will work after unimesh is set. No use in speculating until all the cards are on the table.
Thread: Need help with creating gloves | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
You need to do it manually in yr modeler
The splitting between the fingers sounds like a grouping issue. Need to have atleast one string of the hand groups between the fingers. Even if the mesh is welded it will break if the grouping is wrong.
Thread: Import HD morphs | Forum: Poser 13
