34 threads found!
grayhuze | 0 | 35 |
(none)
grayhuze | 5 | 131 | ||
grayhuze | 7 | 31 | ||
grayhuze | 5 | 31 | ||
grayhuze | 4 | 29 | ||
grayhuze | 1 | 20 | ||
grayhuze | 2 | 23 | ||
grayhuze | 4 | 28 | ||
grayhuze | 4 | 34 | ||
grayhuze | 1 | 9 | ||
grayhuze | 4 | 22 | ||
grayhuze | 2 | 20 | ||
grayhuze | 2 | 47 | ||
grayhuze | 0 | 22 |
(none)
grayhuze | 5 | 40 |
32 comments found!
Thread: Missing Lights, "No Figure"...Possible Corrupt File? Please Help :) | Forum: Poser - OFFICIAL
should save multiple copies as you go. You know, different versions. Then you can go back to a previous one.
Thread: Poser 5 automatic animation tools - Does it work for MIDI? | Forum: Poser - OFFICIAL
Mimic by lipsinc can do this. Just assign different body morphs to the different lip movements. Or just read the cr2 file a figure out what yo need to do. It's pretty cool. I animated a coke can using the Nike bball commercial music. It worked great.
Thread: Pleas Help | Forum: Poser - OFFICIAL
Well, I got it to work. I installed poser4 in a different directory. Moved the Cr2 and OBj to there corresponding directories. when the cr2 opens the obj, it creates a cr2. the poser extension in raydream needs to be edited so that it accesses the pose.exe of the poser 4 program, not the propack. This allowed for an animation of michael in Raydream.
Actually, the plugin works in both 5.0 and 5.5. I have used it in both. I own michael and its .rsr. Like you said though, I have remapped the obj file under a new name. My cr2 file works with it, but why doesn't it create an object RSR anymore.?
The Raydream plugin still works with poser 4 and propack, You just cant have clothes on the character. Robots and other characters like poser 4 nude, michael nude work as well. You have to remap Michael though onto one texture map. I just need the geometry RSR.
Thread: Catarina | Forum: Poser - OFFICIAL
yeah, there she is, Perhaps, well, obviously I had remembered here name wrong. I just don't see stuff from here very often anymore.
yeah, but where is all her art work and merchandize. It is as if she got pissed and removed everything. Even a search only turns up two hits.
Thread: Main window problem | Forum: Poser - OFFICIAL
That is the problem, look at the picture. I have fixed the problem however, by going to preferences and loading up the factory presets. Thanks anyways Gray
Thread: Final Fantasy 1-10 | Forum: Poser - OFFICIAL
Just saw Final Fantasy today. Unbelievable!! After time, you forget they are 3d. The main male character and I share first names...as crazy as Gray is. The movie kind of makes me feel a little insignificant in the 3d world, but I love doing it, so I will continue. Has anyone use the Franko Sr texture map given away for free in the poser section? I have, it is great and very real looking. later Gray
Thread: Eve 3 | Forum: Poser - OFFICIAL
Thread: Mimic and Poser | Forum: Poser - OFFICIAL
Yes, that is what I have been doing. I used a coke can. really works well, I am not sure which morph target responds to the highest wave..like a drum beat. I still like the results though. good luck Gray
using Morph managager, you rename the body to head, and make sure the morph targets have the names that mimic uses. just create a pz2 file and open it in notepad. you will see which morph targets are used. create a character that is named haed as the body and morph targets. it is really cool.....
Thread: "Spawn morph target "and "create full body morph" don't work | Forum: Poser - OFFICIAL
Thanks, I am sure that would work. It is strange that posing doesn't change the geometry. Joints bend etc.
