27 threads found!
grid | 1 | 24 | ||
grid | 21 | 356 | ||
grid | 11 | 275 | ||
grid | 3 | 249 | ||
grid | 20 | 580 | ||
grid | 3 | 127 | ||
grid | 6 | 226 | ||
grid | 7 | 210 | ||
grid | 7 | 198 | ||
grid | 3 | 153 | ||
grid | 9 | 270 | ||
grid | 7 | 165 | ||
grid | 1 | 63 | ||
grid | 10 | 150 | ||
grid | 13 | 289 |
82 comments found!
never mind..
the new image file created was at 300dpi (resolution)
it seems for brushes it cant be that high 200 seems to be it. For "creating" that is, but you can stamp them on to a new back ground at 300 dpi so as this works for me....
first time i ran into this problem =)
Message edited on: 03/14/2006 16:59
Thread: Making ne uv maps with out starting all over! | Forum: Poser - OFFICIAL
I will give this a try I dont give up as esely as you think i have been trying this for six months off and on Realy i have. I have pro and p5 same thing happens in both versions its just crazy to me I had 2 object files with the same problem when i started this thread the wierd thing is the first one went smothly open it in uv mapewr pro change the map save obj file and tex map and bamm!! it work fine. But then went to the second one and its said no uh hu ant ganna happen!! well I will work on it this weekend!
I have done this as well but it seems to me poser keeps recalling it I deleted it all! =( its ok I just gave up with it i try a year from now thanx for all the info
well to say to your rotat the model its the same exact thing on both sides same place and ever thing. When rendering them the are still the same i have not the answer for this one. I fixed one just like this 2 secs b4 this one. got me. this problem is only showing up in poser
Thread: PHI Builder help.. | Forum: Poser - OFFICIAL
Thanx for the help. What i needed was another body part. this would have resovled it all. wich im thinking of doing right now.
Message edited on: 02/06/2005 08:21
Thread: 1 dial control 2 | Forum: Poser - OFFICIAL
Its figure i made it has 6 movin parts i want all six to have there sepret dials, but would like to control 2 of them with one for ezy anymation sequencin.
Thread: define brushes (none select able) | Forum: Photoshop
