15 threads found!
grunthor | 3 | 94 | ||
grunthor | 6 | 174 | ||
grunthor | 4 | 113 | ||
grunthor | 4 | 221 | ||
grunthor | 8 | 267 | ||
grunthor | 6 | 110 | ||
grunthor | 8 | 247 | ||
grunthor | 10 | 294 | ||
grunthor | 2 | 83 | ||
grunthor | 31 | 635 | ||
grunthor | 9 | 211 | ||
grunthor | 11 | 246 | ||
grunthor | 1 | 88 | ||
grunthor | 5 | 139 | ||
grunthor | 7 | 260 |
125 comments found!
I've had the same problem with Ultimate Hair not importing to V5i. I think the problem is in that specific product and not Poser or Vue. My other conforming hair works fine so I don't use Ultimate anymore.
Thread: Vue 6 feature list | Forum: Vue
SolidGrowth applied to cloud generation. I'd love to de able to have a big ominous thunderhead in Vue instead of painting one by hand.
Easier water manipulation. Waves, surf, etc.
Thread: Lost expression | Forum: Vue
Thread: Question about Importing DEMs | Forum: Vue
OK I must have had a senior moment there. I hadn't unzipped the files yet. However, now I have the same problem but with 18 new files. These all look similar to "7517CATD.DDF." They import but they all seem like flat planes. The area I selected is quit hilly (I grew up there).
Message edited on: 05/26/2005 04:11
Thread: Question about V4P and WinXP SP2 | Forum: Vue
I think you're on to something there. I wrote to e-on and got the following response: Hi James, It seems you have lost your collections. Try copying your original Vue4.env file (located on your application CD, Environment folder) into your Vue 4 Pro Environment folder. Best regards. John Canver Once again e-on comes through with a fix. I copied the file over and it works fine. Looks like SP2 is corrupting some files when it installs.
Thread: A face on a name | Forum: Vue
Thread: * * * DECEMBER CHALLENGE - THE WINNER IS... * * * | Forum: Vue
Thread: S3P Hair Problem | Forum: Vue
Good point Mazak. It's probably memory. I don't have much on this machine. I'll try the PZZ format.
Thread: * * * DECEMBER CHALLENGE IS CLOSED - PLEASE VOTE * * * | Forum: Vue
Thread: ...shhhh...just had to say...I GOT POD at e-on... | Forum: Vue
Thread: Image in the 2004 DAZ Calendar | Forum: Vue
Thread: ATI problems with Vue 4 Professional | Forum: Vue
Your amount RAM isn't the problem. 256 Mb of RAM works fine for me. It IS slow, and I can't multi-task. But as Djeser said, that's normal. In addition to what the others have suggested you might want to clear out some more hard drive space. Since your don't have much RAM Vue will rely on your hard drive a lot more. This is one reason for the slowness. Run a good RAM diagnostic to make sure all of your memory is working right. A good portion of the errors people have reported when running Vue 4 Pro have been traced to bad memory locations in high memory that aren't usually used by other programs.
Thread: It's here! | Forum: DAZ|Studio
Thread: V5I vs. Poser 6 | Forum: Vue
