1 threads found!
Posted Sep 03, 2005 at 10:31 pm | Forum: Vue |
h2odog | 1 | 3 |
7 comments found!
I'm not aware of any conversion programs for vob files. Vue 5 Infinite is the only option, and even then not all vob files will export. It depends on the creator of the vob file and whether or not they chose to allow export when they created the file.
Thread: giant city | Forum: Vue
What are you building your ecosystem on? It won't populate on the ground plane, for example, because it's an infinite plane. Try using the plane object in the primitives objects and make sure it's scaled large enough.
Thread: How do I add materials? | Forum: Vue
Using Windows Explorer, navigate to your Vue 5 Infinite program folder (usually c:Program Filese-on softwareVue 5 Infinite) You should have a folder called "Materials". Place the materials in that folder. If you had Vue open, close it and restart. Your materials should now be loaded. Anyway, that's how I would do it on a Windows machine. I'm not sure if a Mac is the same process.
Message edited on: 01/27/2006 08:19
Thread: Our Little Cottage is now Free | Forum: Vue
Thread: Free cars? And a re-importing problem... | Forum: Vue
Attached Link: http://www.planit3d.com/index.htm
Planit 3D has lots of free cars, mostly 3ds format.Thread: Free Vue 5 Human Skin Mat Available | Forum: Vue
Thread: POD | Forum: Vue
Thread: Can vob files be converted for use in other programs | Forum: Vue
