3 threads found!
jayhawk | 3 | 108 | ||
jayhawk | 7 | 153 | ||
jayhawk | 3 | 129 |
33 comments found!
Thread: Poser 6 and Mac OSX 10.4 (tiger) | Forum: Poser - OFFICIAL
Poser6 is not compatable with 10.4.x. You have to install the service release. That seems to take care of the problem.
Thread: osx tiger and poser4/5 | Forum: Poser - OFFICIAL
I have had this problem. Never had a problem with Poser5 on 10.3.8. Since upgrading to 10.4 neither Poser5 or 6 work at all. After writing notes to both, I was told that I need to wait for the upgrade for both the OS and Poser. Frustrating to say the least. Stick with 10.3.9 until the upgrades are in place. I'm sorry that I did not!
Thread: Free Model this week....Toon Car | Forum: Poser - OFFICIAL
Thread: Any interest in a tutorial for creating Poser clothing | Forum: Carrara
Ive been looking for something like this, so it would be quite welcome! Thanks in advance.
Thread: Problem with Mike and Vickie 3 Morphs | Forum: Poser - OFFICIAL
I had the same thing happen. This may or may not help. I re-installed V3.All of the icons were there in the folders but they were empty. Daz put them up for me to download again (which I did) and that did not help. I tried several times to no avail and the icons were still empty. This did work... I installed V3 to the desktop and installed the parts into poser5 by hand. Hope this helps you!
Thread: C4Pro Transposer Reads Bump Maps Incorrectly | Forum: Carrara
Same problem. Set the bump in Poser to anywhere from .01 to .03. That has cured the problem for me.
Message edited on: 12/28/2004 06:22
Thread: A file from way back in the Corel Dream Days! | Forum: Carrara
Thread: Update: Complete Hair Tutorial v. 1.0.0 Now Finished | Forum: Poser - OFFICIAL
Thank you so much. It is just what I was looking for. I have not read all of it but so far it is going to be a great start for me!
Thread: Need Guru Help! | Forum: Poser - OFFICIAL
Thank you for all of your help. Karen and the rest...First I made the face in the face room and applied it to the Judy model. Hence, in the material room I worked with that, ignoring the original head. Thinking about it,I gave the original head the same settings as the other one. Now, in rendering in P4 settings I get "nubs" where the eyelashes should be but in firefly I still get nothing. Now, if I could find a way to lengthen them I might have the problem partially solved. Is there something I should look for in the firefly settings? I did try setting to zero and I do get a solid, so it does indicate that the lashes are still there and yes I did check to see if the transpariency was selected properly. Thanks to all for taking the time to make suggestions. jayhawk
Yes Karen I do. I have tried all kinds of combinations with the lashes. As I said, I can see the transparency dots before I render but can see no lashes at all after it is rendered. I have them colored as black right now but have tried all different colors, including texture strength. It is quite frustrating because there is no info in the manual at all. I cannot find anything on CL website either. Thanks for the reply. If you can think of anything else, I would appreciate it.
Thread: MAC crash | Forum: DAZ|Studio
Yes, I had the same thing happen. It seems to be better if you keep the render size to no larger than 640x480. It worked for me that way.
Thread: ++++++ 'Digital Babes' site update' ++++++ | Forum: Poser - OFFICIAL
Thanks Koz...I really appreciate all of the hard work you put into this. Makes my work a lot easier! As usual this is top notch!
Thread: Carrara3 trees... | Forum: Carrara
Have to agree with you Mark...I was quite impressed with it too! It was one of the first things I played around with when I received the beta version of C3. One question...what did you use to generate the grass? It looks really neat.
Thread: I think renderostiy should adopt this picture! | Forum: Poser - OFFICIAL
