1 threads found!
jrs100000 | 12 | 283 |
9 comments found!
You are looking for www.blenderstorm.org/
They dont take money at this point but there has been some talk of adding that feature. However, there are problems such as deciding who gets to take on a project, when to consider a project finished, coding standards, and continuing support for features after initial development. If those problems are ever worked out, some sort of bounty system could potentially be put in pace.
Thread: If only the topology brush... | Forum: Blender
Set your camera at a slight angle to the surface you want to add wrinkles too. Enter sculpt mode and use the grab brush to pull fabric down to create folds. After the rough shape is marked out use the pinch and smooth tools to detail the folds.
If you just want surface wrinkles, set up a sculpt bush using an image texture (of fabric wrinkles) and use the draw or layer brush set to a low level.
@Haloedrain The Blender Foundation does not handle this sort of transaction so you would have to make the arangements on your own. You can find several experienced Blender developers available for hire at www.blendernation.com/category/store/freelancers/
Thread: dumb question: circular cloth | Forum: Blender
Thread: 24.7 | Forum: Blender
Hmm I believe that is "working as intended". The domain mesh becomes the actual fluid when baked and the bounds of the domain become invisible. If you wish to view or edit the original domain you can either change you view setting to bounds in object mode (for the entire scene or for just the domain object by changing view type to "bounds" under the F7 object tab), or tab into edit mode with the domain selected.
Quote - I'm still waiting for the fluid sim to get fixed after the move from 2.43 :(
Why, whats wrong with the fluid sim? Theres nothing open on it in the bug tracker, so if there is something about it thats broken in 2.47 you should either open a ticket or post the steps required to duplicate the error and Ill open a ticket for you.
Quote - Is that the first of October?
Thats the target date. It should include the Apricote branch, one or two of the GSOC projects, ocean sim, grease pencil, and probably some other stuff.
Not really. There wasnt much in the way of new features.
2.48 should get a bit more attention when it comes out around the first.
Thread: Does Blender have a layer property box? | Forum: Blender
What kind of layer are you thinking of? If its a texture layer, you can hide it by unchecking it in the layer selection box and change opacity by adjusting the amount of color (or other properties) using the slider bars. If its an object layer you can hide it by deselecting that layer, however you would have to change opacity by adjusting either z or ray transparency.
