4 threads found!
jura11 | 9 | 437 | ||
jura11 | 6 | 157 | ||
jura11 | 2 | 348 | ||
jura11 | 2 | 140 |
418 comments found!
Here are two renders of my scene with V4,SSD failed but manage it recover something and scene is almost done,justnot decided on floor and few props but hopefully it will be released soon and I'm so sorry for that
Thanks,Jura
Thread: Poser 11 to Poser 13 and best desktop specs for Poser 13 | Forum: Poser 13
jngzsz posted at 2:17 AM Wed, 12 July 2023 - #4469871
One thing that occurs to me is:
Motherboard + Intel 9900K + 2 Nvidia 3080TI offers more performance than an I9 13900KF + 1 Nvidia 4090?
I mean in render tasks only. The theme of video games is not my priority
Hi there
RTX 4090 will be faster there than dual RTX 3080Ti when comes to rendering,I have tested dual RTX3090 vs single RTX4090 and RTX4090 will win hands down,where dual RTX3090 will and is advantageous is in pooling memory(for dual RTX3090 you will have 48GB of VRAM) but for that you will need to have NvLink and renderer must support it
Plus main reason why I would go with single GPU over dual GPUs setups are electricity bills here in UK or in EU,dual RTX3090 in normal system will pull easily 900W just for GPUs and newer RTX4xxx are much more efficient
And as @shrdavid said,dual GPU won't be as twice as fast,they don't scale as power,trust me I have run all the time dual or triple GPUs setups and they don't scale as you think
Hope this helps
Thanks,Jura
Thread: Show your Poser 13 renders! | Forum: Poser 13
Here are few renders on which I'm working as freebie,I hope it will be released by end of the this month,still not happy with few things like black prop bug
Thanks,Jura
Thalek posted at 10:38 PM Fri, 12 May 2023 - #4465154
Thank you therejura11 posted at 9:22 PM Thu, 11 May 2023 - #4465042
Your work is incredibly detail-oriented!Here is render of TruForm Industrial Loft with my props and textures,rendered in Poser 13
I hope some of these models I will release soon and see how it goes
Thanks,Jura
Here are few renders of bedroom which I'm planning to release.I'm not sure if this become freebie or paid product but let's see
For me DOF is must,I use DOF all the time when I do final renders,for test renders I usually don't use DOF,but I agree it's choice which you can use or not,it's personal preference
Thanks,Jura
My new freebie Modern Kitchen is finally done and uploaded over here on Renderosity and please enjoy it
Thanks,Jura
Really beautiful renders guys and gals,exported from DS Genesis and rendered in Poser 13 and postworked in PS
Thread: Back after a long hiatus | Forum: Poser 13
Thread: Poser13 superfly ( A High impact on your Bill ? ) | Forum: Poser 13
Any render engine will result in higher power consumption,sadly that's the downside if you want to render with CPU or GPU,upgrading to newer GPU can result in lower consumption or lower power limit on GPU through the MSI Afterburner and agree 5 or 6 renders wouldn't pull 3kwh no way
I remember I have run 3xGPUs in one system and that sucker would pull 1500W from wall during the rendering if I unleashed whole potential
Have look on Kill-A-Watt meter they're available online for good money and they're pretty accurate
Hope this helps
Thanks,Jura
Here is few of my renders in Poser 13
Few years back I was dreaming I could do such renders in Poser,right now I'm doing renders which are comparable to other big names in rendering
Hope this helps
Thanks,Jura
Thread: Poser 13 Rendering | Forum: Poser 13
Hi there
If you rendering with CPU,try to use lower bucket like 16 or 32 you need to find perfect balance,128 is quite big bucket size for CPU,if you are using Nvidia GPU then I would start with 512 or 256 and try area lights as well,for indoor scenes area lights are best
Hope this helps
Thanks,Jura
Thread: Skinning method and mesh tearing | Forum: Poser 12
Hi there
I have seen that only when you are using Poser Unimesh method,if you are using that method and you are seeing the mesh tearing, I would recommend play with Subdivision levels 1 or 2 should help and if not then use as above Sasha 19 which I use as well and no problems
Hope this helps
Thanks,Jura
