5 threads found!
kinboat | 5 | 119 | ||
kinboat | 6 | 149 | ||
kinboat | 5 | 353 | ||
kinboat | 16 | 308 | ||
kinboat | 0 | 39 |
(none)
8 comments found!
Well I've tried several times to reload the figure and it hasn't fixed itself... I used the setup room. There aren't really any morphs on it at the moment. If you are willing to take a look at it PhilC that would be great (as long as you tell me what was wrong and how to fix it). I'll send the file along later tonight if that's ok (it shouldn't be too large zipped up). Thanks
Thread: Loaded figures don't show up | Forum: Poser - OFFICIAL
Yep that worked... For some reason the zip was setup to install the OBJ files in the wrong folder. Thanks for helping me out.
Well that might be it, although I haven't tested it yet the CR2 file seems to be looking for it in a different folder. Thanks I'll test it soon.
Thread: Poser 4 rendering problem | Forum: Poser - OFFICIAL
Ok... I just want to thank everyone for their help here... I finally got the right drivers downloaded and working and now I can render a full scene of the Dragon (textures at full resolution too)... It's probably something I should have thought to try myself but then that's why these boards are here (to help the brainless like me to remember the obvious :) ). So special thanks goes to poseschool for being the first to slap me upside the head and mention video driver updates... It does obviously render slower than other images I've done but I expected that. Thanks again :)
Don't have Bryce so that's not an option... I did manage to render just a head shot with full textures but I guess I'll have to shrink some of them antway. I'm having some troubles with downloading video drivers but I think I can sort it out... My computer just doesn't look as good as it did before :)
Thanks everyone... I'll check out new video drivers... And artbyphil, just how small did you have to shrink the textures? As for updating to a newer windows version... I'm not made of money :) I guess if that's the only way it'll work I'm out of luck.
256 on the Low End?! Jease... I was running it on 128 until just a few weeks ago (before I got the Mil Dragon) and didn't come across any problems... I'll have to check on the patch, and I have a 500mb swap file... Bigger or is that fine. Thanks for your help.
Thread: Poser 4 Joint problems | Forum: Poser - OFFICIAL
