We couldn't find any threads matching the specified search criteria.
2 comments found!
To avoid data loss, you should double check and back up important files before performing this operation. fnaf onlineI've taken a quick look into the DIM settings and haven't noted any way of resetting the app. Taking this into consideration, the only option I would recommend is deleting all the installed runtimes/content folders, clicking accept, and rebooting the app. As for the log of installed files, those are handled and stored in a different folder and would most likely disappear if you uninstall content through DIM, provided you are still connected to DS. Otherwise, this might need to be done manually.
Thread: Suggestion for Market Search | Forum: Suggestion Box
Thanks for sharing this great tip! Searching for specific price ranges like on eBay is helpful, especially when you are shopping on a budget. It saves time and helps you find items that are more relevant to your needs. Monkey Mart
Thread: Change Poser and Daz install paths/directories | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
