We couldn't find any threads matching the specified search criteria.
4 comments found!
wow thanx :}} my approach may sound coplicated, but it took me few minutes to finish(2-3)(years of suffering with shortcuts) i started by duplicating. that added motion blur on the layer beneath (no path)(big radius,90 vert.)when u add big radious of blur picture gets transparent so i copyed layer several times(like 5-6) and than merged it. added path to cut it and ruffly selected the crack on the top of the stone with laso and rotated it. i errased the raw sel. aprox to fit and spayed it little. since i had my brush on :) i sprayed some more extending the bump (wouldn`t call it a crack) on the left(picking color from the original pick so it fits) i also erased a tyny bit of space witch crack and bump holds, also on the top shell. used selection of top shell and feather it for 2 ph to make the edge look more stone-like. flattened transparency without background. used selection and added some atmosphear shadows(brush/erase). i think thats it. errr now that i have wrote it , i think that it could be done much easier with simillar results..donno... what do you think? anyway im very glad that i had my first feedback on renderosity.:) Marko
Thread: Aura Effect?? | Forum: Photoshop
question is good, and its cool to know how to make auras but the answer is tooo wide. since we dont see auras very often in our real life, you can improvise. aura on the realistic photgraph have very little to do withe the one u emake for drawing or edited photo...i`ll be glad to help if you could post exzact image though...
Thread: hello there... | Forum: Photoshop
Thread: What do you think of this approach? | Forum: Photoshop
ill check your sistem as soon as i wake up tomorow, sounds interesting. didn
t learn so much abou lab so far part from the trick that one photographer tought me. (goes like this....very simple...) -whem you look at the lab histogram you se a rise, top and fall of values, ut formes a mountain like shape (when it comes to normal, not heavy compressed photos). just move the sliders aprox to be beneath the highest value of histogram (top of the shape). if you do that on all chanells you should se improvement like/ a photo that went in cyan by 5-10% will be set to normal...) i tryed this several times and it worked ok if you try it tell me how it went
