3 threads found!
marble | 12 | 657 | ||
marble | 1 | 132 | ||
marble | 6 | 191 |
18 comments found!
FVerbaas posted at 3:23 PM Thu, 22 September 2022 - #4445056Dammit - I must have missed Genesis 7 somehow!Victoria was not the default Genesis 1, 2, 3, 7 or 8 figure.Real reason becomes clear:
the figure will not be the default coming with DS, it seems.ย
Thread: I don't want Poser Promo emails | Forum: Community Center
Ok - then it looks like your change has worked. I have not received one today or recently.
Thank you.
I don't know until the next one is due (and I don't know when that is).
Why not just put an Unsubscribe Poser Pulse switch on the Newsletter Subscription page?
Thanks. Hard to believe that they are not aware of their own promotion options but a reminder can't hurt.
Thread: BreastJig Script not working with G8F as stated in Description | Forum: MarketPlace Customers
Maybe Lola69 has withdrawn it pending an update. If so, I do hope we are notified about the update and what it does.
It would be helpful if the vendor would comment here on his thread.
Thanks @TheWeezel - I'll give it a try when I return from my holiday (mid-August).
@jennblake ... is there a time limit on refunds? I really can't do any testing for at least 3 weeks or so and it is already a while since I bought it. I'm encouraged that there seems to be a solution, however.
TheWeezel posted at 2:06PM Sat, 27 July 2019 - #4357971
Update I was contacted last night by lola69. It seems there was another way to use this. There is the Script which does not work with G8 but is the only thing indicated in the description or the documentation. There is also the pane that is added in by the plugin and is not noted down in any literature. I have tested it and confirmed it does work. I have also informed lola69 that the email they have on file with you is bouncing back so they should update that to prevent confusion in the future.
@TheWeezel - I also bought the script but am away on holiday and cannot test it. Would it be possible to add a screenshot to show what you mean by the undocumented pane and what you did to get this to work. I've been following a thread elsewhere with a user pretty upset that the product doesn't work (described as "useless").
Thread: Interest in a VWD forum? | Forum: Community Center
I'm a DAZ Studio user and I don't have the $65 but I want this software so I will save for it and hope for a sale or introductory offer when it is ready for DAZ Studio. In the meantime I would like to learn what I can and a dedicated forum would be a good idea.
Thread: Poser Dyn clothing now in Daz Studio | Forum: DAZ|Studio
boudicca36 posted at 7:28PM Wed, 06 April 2016 - #4264413
Could try saving the the _dyn prop as [whatever it was called for a dynamic clothing item] then remove the 2 files from the scene ... load the new saved _dyn prop and select it. If that doesn't make it to show in the plugin, I hope the script writer can help you.
... did you try any other items, very simple items in case the problem is with the garment. ... sometimes closing D/S and opening it again makes things work again ... there was one prop I was trying to have made that just wouldn't take until after a refresh of the program.
Thanks for the tips but, yes, I've tried all you suggest already. I have sent a PM to Lola69 (last Sunday) but so far no reply. I don't hold out much hope though - I gather very few vendors test on the Mac platform even though both Poser and DAZ Studio run on Mac. With DAZ, I can always return the product if it doesn't work but that's not the case here (as far as I know).
I did try it parented and unparented - still no joy. I see in the reviews on the product page that a user named MacSavers has it working with some help from the vendor. I left my own review asking for more information.
Cabiria999 posted at 10:04AM Sat, 02 April 2016 - #4258533
Hello, I have bought the plugin and experimented a bit with it, following the pdf tutorial (the biscuits cardigan on G2F). Unfortunately, I'm stuck at the point when it says: "Go to frame 0 and transform your conforming cloth in a prop." If I select Figure --> Rigging, I don't have the "Convert Figure to Prop" option in the cascade menu. I have also tried to contact the vendor via sitemail, but obtained no reply. Any help is appreciated, thanks in advance.
I found it under Figure > Rigging but not from the Edit menu in the top menu bar but in the Edit menu in the scene drop-down menu.
I have another issue though - I'm wondering if this scripts works at all with my setup. I have DS 4.9, Mac 64 bit version. I get to the stage where I run the script and have a Prop_dyn in my scene but the Dynamic Clothing plugin (paid-for version) refuses to see it as dynamic cloth. It just does not see any clothing in the scene at all.
Thread: Diva V4 | Forum: MarketPlace Showcase
[Note: I also posted this on the DAZ3D forum]
Please could you explain why, when using this character with DAZ|Studio (standard settings and shaders, etc.), the skin tone looks more Dark Asian that Light-skinned North European?
I don't have Poser so can't compare but the D|S renders (and previews) look absolutely nothing like the promo images posted here. I did install both zip files as advised in the install instructions.
Thanks in advance,
Dave.
Thread: Genesis 9 announcement! | Forum: DAZ|Studio
