2 threads found!
Posted Dec 29, 2005 at 9:07 am | Forum: Carrara |
marklaurint | 3 | 17 | |
Posted Feb 28, 2005 at 9:16 pm | Forum: Carrara |
marklaurint | 8 | 142 |
4 comments found!
Thread: creating a moving graph line in carrara 4 | Forum: Carrara
Thanks shonner: I've tryed this and it works, but how do you keep the all the points close enough together when you change direction of the line? Can can you stack the points on top of each other, or do you zoom way in to see the individual points? I'm able to drag all of them together and leave one point behind as I continue elongating the line, but this leaves a straight portion of the line containing the unused points that doesn't follow the direction of the line, especially the first couple changes of direction of the line. Thanks everyone for your help.
Thanks Markd, But I need the line to start very small and grow smoothly along a fixed path. I can use the cloaking tool to hide line segments and uncloak them at keyframes but this is has too jerky an effect.
Thanks Chuck but I've been trying this for the last day. I extend the line by dragging the point along the axis, then set a key frame, this will work for the 1st point. To change line direction I then add a point on the line near the one I moved so the line will stay at that value. Then I continue extending the line by dragging to the next value and set another key frame. The line would look similar to this //_/. When I do this the line will not animated from point to point, instead it will track from the final point to the starting point. Is there a certain order to add points and set key frames? Does anyone know of a tuitorial?
Thread: Star war text crawl | Forum: Carrara
